Multiple subs vs. Room treatments - Page 3 - diyAudio
Old 7th November 2012, 03:54 AM   #21
djn is offline djn  United States
djn's Avatar
This is just an audio room. Because of the door and stairs on at the back of the room, and a laundry room door to one side, the placement is rather fixed.
Old 7th November 2012, 01:38 PM   #22
jbell is offline jbell  United States
that's kinda what I figured I'd hear.... bummer.
Only thought I have for you. Cut your OC703 in 6" strips. Go to home depot and buy some of the largest concrete tube they have, make 3 vertical equal cuts so you have 3 "cylinders" for diffusors per tube. Using thumbtacks or whatever is needed, put them unfinished on the walls so the top is about 12" from the ceiling -- alternating between diffusion and absorption with only a couple inches gap between them. Line each wall.
If that gives you "enough" and it makes your room livable, finish them however you see fit.
Move your speakers wider, and add some more toe-in. That will help reduce your sound bouncing directly off of the back wall. Whatever you do, you don't want your speakers 4'-5' from any wall surface. (google for room mode calculator if you haven't already)
What speakers do you have? aka, do you have horn loaded HF drivers? ribbons or dome? I'm obviously concerned with more than just a 250hz notch in your room.
Old 7th November 2012, 02:06 PM   #23
djn's Avatar
Here is a are bad pix of my speakers. They have changed somewhat since these were taken. They are heavily braced JBL Barzilay cabs with the Lambda TD15X drivers, 350hz Edgarhorns with JBL 2441 CDs with Radian Mylar surround diaphragms, and Big *** Heils for tweets.
I am crossing at 500hz and 5khz. Although I just picked up a DBX active crossover and will go back to active and see what sounds best.
After reading a lot of good thinking here and thinking about how to approach this, I have prioitized it into three steps.
1. absorption panels to kill the 250hz resonence.
2. set up multiple subs to flatten the responce below 50hz or so.
3. deal with reflectivity, back wall, side walls, and ceiling.
Old 7th November 2012, 02:23 PM   #24
djn's Avatar
By the way, in the pic of the back wall you see 2' x 2' louver doors. That leads to a 4'w x 5't x 3'd storage space. I don't know what I can really do with that that might help.
Old 7th November 2012, 02:44 PM   #25
measure from center speaker cabinet to side wall -- what is that dimension?
Old 7th November 2012, 06:40 PM   #26
djn's Avatar
The center of the woofer is 3.5' from the side wall and 2' from the back wall.
Old 7th November 2012, 08:19 PM   #27
auplater's Avatar
Sub placement is kinda funky... very room dependent.
Try to get one sub off the floor (maybe up behind that louvered door), another one near one or the other front corner, and a third one (if you have it) halfway between front and back, preferably off the side wall if you can stand it... at least this has worked for me for 20 years or so
John L.
"I've forgotten more than I care to remember" The Last Conspirators
Old 7th November 2012, 08:28 PM   #28
Face is offline Face  United States
Face's Avatar
Have you taken any actual measurements of the room yet?
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 7th November 2012, 09:41 PM   #29
djn's Avatar
John L.
Thanks John. I had an idea when reading your post. I have two good subs one in each front corner of the room behind the speakers. And I have the makings of two more subs. What I though of was to make that big space through those louvered doors the back chamber for a third sub. I have two 12" sub drivers that I'v never used because they need at least 8cu ft to go low. If I make that opening into a baffle, and mount both drivers in it, that could work well......I think.
I did take measurements Face, but then send the OmniMic back to the owner and realized I did not save the graphs. But I do know that I have a room resonance at about 250hz.
Old 7th November 2012, 09:44 PM   #30
djn's Avatar
Wow, I need to wake up before typing John. I just reread your post and you said "maybe up behind that louvered door". I didn't even realize I'd read that. Just assumed I thought it up. Great idea....thanks.
Multiple dipole subs, can nulls be compensated and room response averaged out? OllBoll Subwoofers 3 3rd September 2012 06:00 PM
room treatments chainenoble Multi-Way 5 17th March 2007 10:21 PM
Room treatments - diffusion & absorption... darkmoebius Everything Else 0 20th July 2005 02:35 AM
2" rigid high density fiberglass for acoustic room treatments? darkmoebius Everything Else 6 6th May 2005 08:44 PM
Copyright 1999-2017 diyAudio
