Bass Horn Idea
Bass Horn Idea
Old 9th November 2012, 02:46 PM   #21
tb46 is offline tb46  United States
Hi 3GGG,
I tried it today with the lastest downloaded version, and it seems to work. Another alternative is to use Hornresp, and its schematic export function.
Just in case you are having problems with the usage of the worksheet, here is my attempt at an English translation of the "Notice":
"Notice:
This worksheet is designed for horns with two walls parallel, the expansion is therefore only in a plane. (One could also call these horns: radial horns). The bass horn by Mr. Roggero is a horn of this type.
An option permits to use a wall of the listening room as a mirror (element of symmetry), this leads to shorter extreme bass enclosures.
To reduce the file size the worksheet has no entries (in the working cells). To enable calculation all items must be in the worksheet "Horn Calculation": copy line 34 from line 35 up to line 4035.
Usage:
The choice of parameters is made in the sheet "Horn Calculation."
In field B10 select the acoustic bass cutoff frequency, knowing that it is desirable to electrically cut an octave above.
In field B11, enter the throat or motor output diameter in mm.
In B14, we can choose the type of expansion:
- 1 in the case of an exponential,
- 0 for hyperbolic.
- The default value for a horn will be 0.707 (hypex).
In B19, we choose a coefficient that defines the type of horn, round or square:
- 3.14 for a round enclosure, and
- 4 for a square.
In B37, a coefficient can be used if you use the room corners and reflective walls to extend the enclosure:
- 2 if it ignores walls (default case), and
- 1 with the walls.
Choose the settings, let Excel calculate (a few seconds) and view the result on: Half horn profile sheet that draws the profile."
Oliver
Old 8th April 2013, 11:54 PM   #22
3GGG is offline 3GGG  Australia
With my 4 way horns running I now need to look at under 120 HZ. The idea is for a bass horn built like a bulkhead into the ceiling.
It will look imposing so I may consider building the horn firing down the rear wall and exiting at the base of the floor.
File Type: png Screen Shot 2013-04-09 at 9.14.50 AM.png (34.9 KB, 256 views)
File Type: png Screen Shot 2013-04-09 at 9.14.34 AM.png (39.6 KB, 241 views)
Old 9th April 2013, 12:08 AM   #23
With a low 2400mm ceiling this doesn't give a long horn enough horn length with 500mm for the driver and an exit of 500mm at the base.
Maybe a fold at the bottom? back to sketch up
File Type: png Screen Shot 2013-04-09 at 9.36.53 AM.png (42.2 KB, 241 views)
Old 10th April 2013, 01:09 PM   #24
epa is offline epa  Netherlands
starting with more area(bigger driver/s)the horn can be shorter.
i like the bulkhead idea,if you need a longer path start in de center then fold around the corner and proceed like in post 22.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 25th August 2013, 10:28 AM   #25
Rewind is offline Rewind  Sweden
Rewind's Avatar
Any luck on this project? I am thinking, why not build a really huge one on the lawn in the backside of the house, and whenever I need some bass I can just open the backdoor. I could have a small indoor spare sub when quality bass is less important.
Old 25th August 2013, 11:29 AM   #26
I have made some progress. Footing have been dug and poured, lintels installed on both the exterior and interior stud walls and block work has begun.
Fc 16Hz, 18TBX100 drivers will be used.
Bass Horn IdeaHide this!Advertise here!
Need help from you bass-horn guru's, re-engineer a horn from drawing. Join Subwoofers 4 9th November 2010 11:45 PM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
Comments on bass horn sim in horn response paulspencer Subwoofers 38 1st November 2005 08:34 PM
another horn idea... SkinnyBoy Multi-Way 26 23rd March 2005 11:03 PM
front horn Idea brsanko Multi-Way 17 28th August 2004 04:19 AM
