diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Trying to choose which drivers to go with. Need advise (http://www.diyaudio.com/forums/subwoofers/222861-trying-choose-drivers-go-need-advise.html)
ClarkDan 4th November 2012 03:55 PM
I am getting ready to start a new subwoofer build and need some advise. I am going to start out building just one and then will build another one to match, around a month later when I am able to save up some more cash for the extra driver. My room is 14 x 18 and these will be used for mostly home theater with a very small amount of music listening.
My budget for the driver is $300.00 ea. I was thinking of going with the Dayton HO18 or Fi Car Audio SSD-18. I am kind of new to this, and those are the only drivers that I have been researching. Can anyone suggest and other drivers in that price range that would be better than the SSD-18 or HO18?
I want to build these in a large ported enclosure that would ideally go down to sub 16hz and also put out a good amount of SPL at those low frequencies. I have no size or space restrictions, no WAF to deal with as these will be going in my man cave.
I am also looking for good suggestions on what amp I should go with. Budget for the amp is $300 and below. Budget for the driver is $300 and below.
Moonfly 4th November 2012 05:51 PM
Either of these drivers should be a good choice, but I only have experience with the Fi drivers, which I cant really fault. An SSD18 will work well in a large enclosure tuned down to 15hz with anything upto 1000 watts of input power. Many people use behringer amps to power DIY subs as they offer lots of power pretty cheaply and one amp can power two subs easily enough. The are pro amps though and come with cooling fans on them that may be an issue for some.
ClarkDan 5th November 2012 12:43 PM
Thanks for the reply Moonfly! Are there any other drivers in the $300 dollar price range that would best a Dayton HO18 or an SSD-18? What about JBL drivers, or Mach5 Audio, or possibly even something like a TC Sounds Epic driver?
turbodawg 5th November 2012 03:01 PM
A pair of 15" HO would be $300 and have more displacement potential. But the amp requirements would be different and you would need a pair of boxes, larger overall.
tb46 5th November 2012 04:14 PM
Hi ClarkDan,
"...I have no size or space restrictions..."
How about the Kraken 212: http://www.diyaudio.com/forums/subwo...-212-th-8.html
ClarkDan 5th November 2012 06:24 PM
Originally Posted by tb46 (http://www.diyaudio.com/forums/showthread.php?p=3229109#post3229109)
Hi ClarkDan,
Wow, that looks so impressive that I have decided to build a pair of Kraken 112's. Might possibly go with a 212 but since this is my first build, I think the 112 might be easier. Do you, or anyone else have the proper deminsions of the cabinet, preferably in inches, for the 112 with the recommended JBL 1214 driver? I looked through a ton of pages on that thread and couldn't really find a decent copy of the specs as far as which widths to cut the panels. Any help with that would be awesome!
hoppaz 5th November 2012 07:04 PM
1 Attachment(s)
I built a Dayton sub for HT. 4.5 cubic feet. Love it and I won't go down the commercial route again.
tb46 5th November 2012 07:35 PM
Hi ClarkDan,
Here it is in Post #94 (some of these threads should be indexed in Post #1, oh well): http://www.diyaudio.com/forums/subwo...ml#post2770682
Quote: "... inner width and the outlet hole is 320mm wide/high. Material thickness is
22mm..." (W_inner=12.598" / Material=0.866")
tb46 5th November 2012 07:53 PM
Hi again,
Before I forget about it: http://www.diyaudio.com/forums/subwo...pped-horn.html , and
in Posts 181/188(updated pdf) I added a single fold small footprint version.
hoppaz 5th November 2012 10:10 PM
What's the cubic feet size of said design?
Copyright 1999-2017 diyAudio
