#31 |
Hi Dan, just to be clear, I'm not a company or anything like that. I live in Spain and there is literally no work out here, so I turned to subwoofer modelling a design work as something I could do that brings me in a little income (more like pocket money). I'd be more than willing to help you out once I have completed a model I am currently working on, which should be done today. Its normally against forum rules for any member to tout for business or ask for payments for services, so I cant directly do that.
I will reply to your PM now though. Mods, if any rules are being broken, please notify me. |
#32 |
FYI: Fi Car SSD18 in a T-TQWT: b
#33 |
Hi bjorno,
That ought to "bring down the house". What happened to the Le in Hornresp :-). Regards,
Oliver Last edited by tb46; 9th November 2012 at 07:24 PM. |
#34 | |
No problem Moonfly, I was planning on sending a donation. I can't ******* wait to see your model! As soon as you get it completed. I am going to start on the build ASAP and will do as much as is possible without the drivers as they are still a few days away. |
#35 |
I'm going to get to work on this model in the next hour or so. Are you wanting to use 19mm material as stipulated in the post above? Also, I need to know the internal width of this cabinet design if anyone has that info available.
#36 |
19mm works out as correct, so thats that sorted. All I really need is the width of the cabinet, the opening detail, and the driver mounting to the baffle details. Do we have those available?
#37 |
Hi Moonfly,
Kraken thread Post #94: Build your own 2x12" TH (The Kraken 212 TH) "The inner width and the outlet hole is 320mm wide/high." This inner width would be applicable for MDF and for plywood, but for MDF the material thickness would probably be 19mm, and for plywood (e.g.: baltic birch) you would reduce the thickness to 18mm, and adjust all dimensions accordingly. Also, it's just not that critical. Just make sure that the driver fits in the box :-). Regards,
Oliver |
#38 |
Sweet. I'l just about to go catch a football game (you know, where you use your feet to control a sphere
), but I am making some progress. I have the basic model down, just need to create the driver, put on the end caps and make the opening, then make the driver up and fit it into the baffle. I should have something to show later on this evening.
#39 |
Making some progress, I just need to Make the model of the driver now and ensure it fits. Looks like the JBL driver is going to be pretty tight.
EDIT: Ive made a driver template. Ive added a second image below that shows confirmation the driver fits. Its tight, but according to the computer model, there is about 10mm of clearance. Only issue I see that may arise is that according to this image, the VC looks to be vented so that 10mm might or might not be enough clearance. Last edited by Moonfly; 11th November 2012 at 09:10 AM. |
#40 |
The Model is now complete. Dan, do you want this with the additional detailing sent just to you, or do you want everything uploading to the thread here?
| Your way to choose drivers | alspe | Multi-Way | 12 | 22nd October 2011 01:09 PM |
| Need 10" drivers and advise | netefx | Multi-Way | 1 | 24th July 2007 11:17 PM |
| 3way idea,help choose drivers | peterpan | Multi-Way | 1 | 11th October 2005 12:47 AM |
| 4 ways with pro drivers advise | Frankx | Multi-Way | 19 | 14th June 2005 04:48 PM |
| How to choose 15" drivers for QSC 2450 amp? | lunchmoney | Multi-Way | 9 | 5th May 2005 06:40 PM |
