Trying to choose which drivers to go with. Need advise
Old 6th November 2012, 11:10 AM   #11
ClarkDan is offline ClarkDan
Originally Posted by tb46 View Post
Hi ClarkDan,
Here it is in Post #94 (some of these threads should be indexed in Post #1, oh well): http://www.diyaudio.com/forums/subwo...ml#post2770682
Quote: "... inner width and the outlet hole is 320mm wide/high. Material thickness is
22mm..." (W_inner=12.598" / Material=0.866")
Thanks for that link. I have read most of that thread, and to be honest, I am a little bit intimidated. Those diminisons listed are hard for me to understand and picture in my head as I have never done any wood working before. Do you know if anyone has made a cutlist with the exact diminisons of each panal in inches? Kind of like lilmikes thread over at AVS on the F-20 horn sub that he designed? I really need some better sketches of this thing before I jump off into it.
Old 6th November 2012, 11:53 AM   #12
Moonfly is offline Moonfly  Spain
If you build create a model in google sketchup you can produce stuff similar to what Ive done in the images attached.
Old 6th November 2012, 12:09 PM   #13
I have never used google sketchup, but I will look into it. How do I figure out the diminisons of each board, preferably in inches?
I wish I knew more about using google, and had the proper diminisons for each panal. That would make this a whole heck of a lot easier! The picture that was linked a couple of post back, is very confusing in the way that it is written, and I just wish there were a more standard cut list for each panal. I really want to get started on the cabinet but I don't know what size cuts to make.
I will order the driver tomorrow!
Old 6th November 2012, 12:15 PM   #14
Are you trying to copy the build detailed in this pdf?
http://www.diyaudio.com/forums/attac...dwg_rev.01.pdf
Old 6th November 2012, 12:27 PM   #15
I am not sure what that model is in the link you just posted, I don't have my glasses with me and that text is very hard to read. The one that I would like to build is the Krackin 112. I want to build two of them.
Old 6th November 2012, 12:35 PM   #16
It looks like they created a google sketcup model of it already. Perhaps you should PM the guy and ask if he has a model he could send you:
diyAudio - View Profile: Petter Persson
If he has a model, but your still not sure what to do with it, let me know, have it sent to me, and I'll break it down for you.
Old 6th November 2012, 01:53 PM   #17
Ok I just sent him a pm asking for a model sketchup or cut list with proper diminisons of each board. You don't know how much I appreciate all of everyones help on this, especially you Moonfly! I am going to wait on ordering the driver until I can make sure thant I will somehow be able to get a detailed cut list and/or sketchup/detailed drawings of the diminisons. I don't want to order the drivers then not be able to get the specs on the cab, thus leaving me with 2 drivers that I would otherwise never use.
Old 6th November 2012, 05:53 PM   #18
tb46 is offline tb46  United States
Hi Moonfly,
I made the drawing you are refering to in Post #14, it is for the Kraken 212, and was to show the sizes of different mouth locations, and the difference between a 3-section and a 4-section Hornresp model. It does not show the individual boards.
What the OP needs is referenced in Post #8 (this thread), i.e.: Post #94 of the Kraken thread, from that he should be able to develop a cut-sheet; the dimensions are in mm (divide by 25.4 to get inches). Or, you could make him a sketchup model.
Oliver
Old 7th November 2012, 02:40 PM   #19
Thankfully, John is working on a cutlist for me. I ordered the drivers just a few minutes ago and will probably pick up the wood to start on these babies this weekend since my fiancÚ is going to be out of town. I am planning on building two of these bad boys, (Krackin 112's). I already have a spare Yung 300 watt plate amp that I purchased from parts express a few weeks ago. Do you guys think I could use that to power one of these Krackin 112's? I know that horn subs are very efficient so I am hoping to save some money by purchasing another cheap Yung 300 watt plate amp to match my other one, then picking up a minidsp to EQ these two subs.
Old 7th November 2012, 04:34 PM   #20
Hi Moonfly,
Ah I see. Well we can see how he gets on, if Dan sorts it out for him then sorted. If help is needed with GS then I can help out there. Can we upload GS models on this forum, if I end up doing one, may as well have it posted here.
Trying to choose which drivers to go with. Need adviseHide this!Advertise here!
Your way to choose drivers alspe Multi-Way 12 22nd October 2011 02:09 PM
Need 10" drivers and advise netefx Multi-Way 1 25th July 2007 12:17 AM
3way idea,help choose drivers peterpan Multi-Way 1 11th October 2005 01:47 AM
4 ways with pro drivers advise Frankx Multi-Way 19 14th June 2005 05:48 PM
How to choose 15" drivers for QSC 2450 amp? lunchmoney Multi-Way 9 5th May 2005 07:40 PM
