Subwoofer: filtering line out - diyAudio
Old 3rd November 2012, 01:32 PM   #1
PsychoM is offline PsychoM  Belgium
Default Subwoofer: filtering line out
I have a pair of active Tascam VL-A5 monitor speakers and I really like them. But they are quite small and their bass response isn't really good (the frequency curve drops from about 100Hz).
That's why I would like to add a subwoofer to my system.
I need an active sub with a line in and (filtered) line out, like the Tascam LF-S8.
My sound source will be connected to the sub, and the line out of the sub will be connected to my monitors.
But I recently found a very cheap Sony SA-W505. It has some nice specs, and it has a line in and line out. However, the line out is not filtered. It just passes the input signal.
Will it sound bad if I use the sub without filtering the line out (so both the sub AND the monitors will put out the low frequencies)?
Is there an easy way to filter the line out? I think it is a buffered line out with an opamp, so if just add some caps, will that do the trick?
Thanks,
Psycho
Old 3rd November 2012, 02:20 PM   #2
You could consider something like this: Parts-Express.com ? Harrison Lab ? In-Line Crossovers, Line-Level Attenuators, High Pass Crossovers, Low Pass Crossovers
Most of the plate amps PE sells have a first order 125Hz filter on the lineout. Perhaps those more readily available to you have similar characteristics.
Thanks,
Psycho
I was so much older then, I'm younger than that now.
Old 3rd November 2012, 06:59 PM   #3
Thank you for your reply! Those seem really interesting!
Old 3rd November 2012, 10:58 PM   #4
tvrgeek is offline tvrgeek  United States
This seems to be a real budget problem, so the answers I will give is in consideration of ultra low budget.
First: Just add a sub and run the monitors full range. I would do this first and see what the result is. You are running them full range now.
Second: Buy a real crossover. Something like the analog Bheringer. Yes, it works fine at line level. Then any old sub will do as long as you can bypass or turn higher the crossover.
Third option: Considering this is the DIY forum. BUILD your own analog crossover. It is easy. If you are creative it can be cheaper than even a used Bheringer.
Fourth option: Many of the car crossovers are not that bad. Most are only third order, but so are most plate amps. So a car crossover feeding the monitors and the plate/crossover feeding the sub.
I would not just add a cap to the input of the monitors. A first order won't do much and if it is not buffered, can cause considerable distortion. If you add an op-amp, that means a power supply, and you might as well add a couple more caps and you are doing option three anyway!
Old 4th November 2012, 02:35 PM   #5
djk is offline djk
djk's Avatar
"A first order won't do much and if it is not buffered, can cause considerable distortion."
Really?
The JBL BX63, Dahlquist DQ-LP1, etc. are all passive high-pass.
" The Dahlquist unit wiped out all the competition...no grain, no audible distortions or colorations" (review by Absolute Sound)
https://sites.google.com/site/mpbarn...hlquist-dq-lp1
http://www.jblproservice.com/pdf/Vin...BX63A%20ts.pdf
And of course Nelson Pass:
http://www.passdiy.com/pdf/phasecrx.pdf
Candidates for the Darwin Award should not read this author.
Old 4th November 2012, 09:14 PM   #6
You're right about the low budget
I was thinking about building a crossover myself. But I don't have the tools to make a proper circuit board, so I guess I will need a kit, I'll search some more for that.
The Behringer crossover is a good option too but it's quite hard to find a used one here, and I'm not gonna buy it new: for that money I'd better buy a more expensive sub...
I'm not gonna get involved in the passive filter discussion
But I was thinking more about modifying the subwoofer electronics: If the sub has buffered line out stage (opamp?), isn't it just possible to add some parts to the output stage like in a real active crossover circuit? Active filters are just opamp stages with some caps around them. So just adapting the subwoofer line out from a full range stage to a filtered stage, would that be possible?
Old 4th November 2012, 10:32 PM   #7
djk is offline djk
djk's Avatar
Look at the schematics for the DQ=LP1 and the JBL, you could easily duplicate that in the line out of your monitors.
Old 5th November 2012, 05:36 PM   #8
SNIP...
The "Active Filter Cookbook" by Don Lancaster is a good resource.
It is all over the net in .pdf form now.
My copy is all worn out.
Years ago I built a State Variable filter using TL082's (actually TL084 quad Op-amp) and it worked great.
Dave
Old 6th November 2012, 03:15 PM   #9
Anything is possible with enough time, knowledge and money.
With crossovers going for as little as $25 used at places like Music Go Round and on Craig's list, spending hours figuring out how to DIY, locating and purchasing the various parts does not seem so cost effective.
Old 6th November 2012, 07:00 PM   #10
Okay guys, thanks for all the tips!
Help with Subwoofer amp Low-Pass Filtering EWorkshop1708 Subwoofers 4 19th May 2009 06:51 PM
Power line filtering lcsaszar Power Supplies 5 11th July 2008 02:38 PM
Best way of filtering bass into my subwoofer? Mal P Multi-Way 1 19th April 2005 03:51 AM
A cure to comb filtering in line arrays Elias Multi-Way 0 5th March 2004 03:59 PM
T-Line subwoofer?possible? Synapse Subwoofers 4 18th November 2003 07:45 PM
Copyright 1999-2017 diyAudio
