Old 1st November 2012, 07:06 PM   #1
Prj57 is offline Prj57  Bulgaria
Default Help me out here
Hey guys, after a long time being away from this hobby, I find myself over my head in trying to build not 1 but 2 subwoofer boxes. What started as discussion with a friend of how I wanted to make a better box for my car turned into a double projectfor me and my friend!
I have to (apparently, the MDF has been already bought) build 2 sub boxes for 2 different drivers for different purposes! I've been interested in car audio since I was kid, but my friends project is for home, using a car sub!!!! As rushed as all seems, the amp is en route and should arrive in 10-15 days!
I'm making this a double project, since both boxes will be built alongside. Now, the car sub which is for my Land Rover is a 10" Audiobahn AW101T. It's in decent box, which some guys built me some time ago, but I always wanted a slot port box!
My friends box is to be using a Pioneer TSW309 S4 car sub in simillar design box, but for home use. Now this is where I'm not sure if I've done my calculations right. Budget constrains force me to use the mentioned drivers for both projects, one is existing the other is in my friend's budget. 50 euro for 19mm thick MDF which is 3.6x1.8 meters - the sheet has been bought already!
I've been reading the forum a lot lately and was wondering if you guys can help me out with the calculations and maybe some tips? I've built my last sub box 5 years ago, from waste MDF boards, even more troubling - this last box was also my FIRST one!!! I don't want to mess up badly with those 2 projects as there's a friend involved and I don't mind screwing my car sub design, but his HAS to work!
First, I want to ask for your ideas or recommendation at this stage? Is it too crazy of an idea to work? Should i reconsider design, driver or anything to try to avoid or focus on? The driver's Fs is 40hz, I'm tuning it to 34hz
I will provide you with design templates, pics and calculations after I figure the upload feature.
Old 1st November 2012, 09:45 PM   #2
tvrgeek is offline tvrgeek  United States
First, down some box design software like WinISD.
Upload: go to advanced and look for the little paperclip.
Old 1st November 2012, 10:01 PM   #3
Shadydave's Avatar
Specs can be found here, including recommended box volume and port dimensions.
Pioneer TS-W309S4 Champion Series 12" 4-ohm subwoofer at Crutchfield.com
Or here Pioneer TS-W309S4 (TSW309S4) 12" Single 4 Ohm Champion Subwoofer
Crutchfield's recommended box volume and port dimensions gives a box tuned to 40.5 Hz.
This box has a 4.4 dB hump at ~57 Hz, is 3 dB down from that at ~ 41 Hz, 6 dB down at ~ 36 Hz and 10 dB down at ~ 30.5 Hz.
The recommended 1.5 ft.^3 (42.5 liter) box W/ 76 mm X 223 mm Port would be
OK for a car with it's Cabin gain.
For home stereo you need at least a 3 ft.^3 (85 L) box.
The port will need to be more like 101 mm ID, with flares if possible.
That will put out well, down to ~ 25 Hz with a 101 mm ID X 300 mm port.
101 X 300 mm tunes 3 ft. to ~ 28 Hz
Better, use a 101mm ID X 450 mm long port for flatter response.(23 Hz tuning)
Or, use a 4 ft.^3 (113 L) box with a 101 mm ID X 245 mm long port (26 Hz)
Even better a 5 ft.^3 (140 L) box with a 101 mm ID X 225 mm long port.(24 Hz)
If you want to use a slot port, with an 85 L box it will be long and probably have to turn a corner.
For instance a 250 mm wide X 40 mm tall slot port will need to be between 350 and 550 mm long.
I imagine this would require a steep High Pass filter at 20 Hz or more to protect the speaker from over-extension.
Like so many car woofers, I can not seem to find all the specs such as DC resistance, Inductance, X-Max, Sd, Cms and the few more that are required to really model this driver.
I suspect that in a large ported box you could not drive it with much power, maybe 100-150 W max, but the smaller Car-sub box helps to protect the speaker at higher powers.
Bottom line, you could make a decent home stereo subwoofer with a pair of 3 ft.^3 boxes, but you will need to have electronics to protect the speaker from hitting it's limits. (high pass filter and power limiter)
For Home Theater (watching TV & Movies) it may not be a good choice.(both the driver and a Bass Reflex box)
Hope this helps,
Dave
Also, don't believe everything you read, try it yourself and learn.
<---My Transmission Lines from a prior life
Top one Tweeter...Bottom one definitely a Sub
Old 1st November 2012, 11:08 PM   #4
Ah, yes, as I feared! My approach is flawed, Shadydave as you said I can actually make the box bigger and keep it simple! There will be electronics involved. The home sub will be driven by a dedicated Bash 300W plate amp. There's not much I can do there - it's in transit.
I am using Bass Box 6 to model my boxes and manged to find some details on the Pioneer sub, here are the specs entered / calculated by Bass Box:
Fs = 39.5 Hz
Qms = 12.47
Vas = 1.064 cu.ft
Cms = 0.00745 cm/N
Mms = 217.9 g
Rms = 4.338 kg/s
Xmax = 10.4 mm
Xmech = 15.6 mm
P-Dia = 260.7 mm
Sd = 0.0534 sq.m
P-Vd = 555 cu.cm
Qes = 0.697
Re = 3.189 ohms
Le = 2.33 mH
Z = 4 ohms
BL = 15.73 Tm
Pe = 400 watts
Qts = 0.66
no = 0.257 %
1-W SPL = 86.24 dB
2.83-V SPL = 90.24 dB
X-max is really a guesstimate on my part, the program then suggests X-mech. Vas is taken from the manufacturer, Qts is also from the manufacturer. I know this sub is over-rated and I don't have equipment to test it even if I knew how! I've worked with Pioneer subs before and they are very well balanced at least to my ear and achieve good sound in moderate enclosures. However, I am looking at this from a car audio point of view when I shouldn't! The box design, I have currently, employs a single 180 degree port bend, while keeping all measurements as equal as possible, but actually making the box bigger will ease the construction and port dimensions.
The box dimensions so far as follows:
H 420mm x W 560mm x D 420mm
MDF thickness - 19mm
Bass Box gives the following results:
Type: Vented Box
Shape: Prism, square
Vb = 59145 cu.cm
Fb = 34.27 Hz
QL = 6.582
F3 = 40.25 Hz
Fill = heavy
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 382 mm
Wv = 50 mm
Lv = 732 mm
QLv = 7
Please note that the actuall desing has a double front baffle, so physical dimenssions are slightly larger. But you can see it in the attachments.
At this stage, I am beginning to doubt the whole design of the box. Any suggestion or pointers?
Old 2nd November 2012, 02:26 PM   #5
ßart West-VL.'s Avatar
I which I could draw as good with Sketchup
The port may get audible because of the sharp bends and likely the tuning will be off.
Old 2nd November 2012, 05:07 PM   #6
Ok, new results.
Following Shadydave's recommendations and Bart's observations I have remodeled the box for the Pioneer sub.
I've got info on the room the sub will be playing in and its huge! It's a basement floor, tiled floor with some carpets, its surrounded by reinforced concrete walls and columns, being part of the foundation of the house. I think this will be vibrating like hell! I spent half of today thinking on the possible issues or effects once the sub is placed in the room. As mentioned, I redesigned the box, made it larger, kept the slot port but got rid of the bends! You can have a look at the attachments.
New box measurements:
Physical dimmensions H 420mm x W 560mm x D 560mm
Since the front baffle is double thickness, measurements for simulation used are:
H 420 x W 560 x D 541 (note, I am using 19mm MDF)
Bass Box 6 results:
Type: Vented Box
Vb = 87455 cu.cm
Fb = 26.85 Hz
QL = 6.582
F3 = 41.86 Hz
Fill = heavy
No. of Vents = 1
Hv = 382 mm
Wv = 32 mm
Lv = 452 mm
QLv = 7
I am adding the response curves from Bass Box, I figure some of the data is off, there are no passive or active filter elements considered in the response curves!
Since the box got bigger, I assume I will have to use some bracing! I have never used bracing before and I'm not sure where to put it! Are there any general guides to follow regarding bracing?
P.S. the schematic is incomplete due to some 45s missing as well as possible bracing, but I did this in hurry!
Old 2nd November 2012, 05:48 PM   #7
Don't worry about the 45's in the corners. (except by the port, like you have.)
Most plate amps have a high pass filter around 20 Hz. So you should be good there.
Braces should be designed to stop the walls from flexing. Look around for pictures of DIY subs for a better idea of bracing. If you can fit them in every 200 mm or so that should do quite well. I don't like MDF for braces, I suggest plywood as it is stiffer. (MDF will work, you just need to use a bigger piece.)
Old 2nd November 2012, 06:08 PM   #8
the graft you posted looks like it's for a sealed box. you might want to double check that.
Old 2nd November 2012, 06:28 PM   #9
Hmm, actually these ARE the right graphs! Same box, but sealed has VERY similar graphs and provides a F3 @ 53 Hz! I guess its because of the driver parameters, the software even suggests SEALED as more appropriate, but I prefer vented boxes
Old 2nd November 2012, 06:54 PM   #10
Totally different picture :
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
