Old 4th November 2012, 02:03 AM   #11
Bill poster's Avatar
How about the Seas L26ROY? A very nice looking 10" driver, not too expensive and apparently sounds tight and fast in a vented box. there are 2 different versions, one is more sensitive and the other probably goes marginally deeper.
http://avforum.no/forum/attachments/...e-img_2136.jpg
Old 5th November 2012, 07:21 PM   #12
Originally Posted by tb46 View Post
Hi ShaQBlogs,
In Post #7 Shadydave mentioned the 1262W. Another driver that appears to be very similar to your Infinity 1260Ws is the JBL GTO1214. There are quite a few builds here @ diyaudio for that driver, and I think they would apply.
Bye the way, I like your choice from Post #8, I would increase the volume if possible, maybe to 120 litres.
Hi tb46,
Whats the reason for recommending to increase the volume?
The 1262 is not available here. It was my first choice.
Thats a neat looking driver.
How does it compare to TC Sounds Epic 12? Epic goes down to 15Hz as per specs @parts express, as compared 20Hz on this one. I read a few good reviews bout Epic. Not many recommendations of it here. Any specific reason?
Old 6th November 2012, 01:16 AM   #13
tb46 is offline tb46  United States
Hi ShaQBlogs,
Reason for increased volume: every little bit helps. Really not a big deal.
For TC Sounds Epic 12, I like it, but more expensive than JBL GTO1214. Also, see: Suggestions Creating Subwoofer Box(s) - 56 cuft available
Oliver
Old 6th November 2012, 11:37 AM   #14
The 1260 seems to be more musical than this. Lower Q parameters.
Also this seems just as powerful as the 1260. The Epic looks like can play much louder which is what I am chasing. Louder and equally/more musical than 1260.
Old 6th November 2012, 01:50 PM   #15
Hi ShaQBlogs,
Post #14: "...The Epic looks like can play much louder which is what I am chasing."
Sounds like you found your driver :-).
Oliver
Old 6th November 2012, 04:36 PM   #16
Hi ShaQBlogs,
thanks
since i havent heard it, i am not sure if it plays really tight.
lm3875 noise problem--suggestion required paku5535 Chip Amps 27 13th August 2012 06:05 PM
Preamp suggestion required pls milen007 Tubes / Valves 4 19th September 2009 03:53 AM
Sub Sat Design input and suggestion required somakmaitra Multi-Way 2 20th May 2008 03:13 AM
Help/Suggestion required for H-Bridge circuit xyz9915 Power Supplies 6 8th May 2008 05:45 PM
Circular saw blade suggestion required. ashok Equipment & Tools 33 30th March 2008 02:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
