#21 | |
simple way of resonance frequency measurement:
Free Air Resonance of a loudspeaker - Eddie Runner Now use that to determine the two high peaks in impedance that comes with bass reflex enclosures. Between these peaks there is a very low impedance and that's the resonance of the total system of your enclosure. ![]() Don't use more than 5V output from your amp to measure with earlier proposed resistance. Exact numbers are not important as you only need to find the lowest imedance between those two peaks. Oh right... you'll need a frequency generator on your computer to feed the amp. Don't get tempted to up the volume! you'll fry the resistors easily.
![]() Quote:
#22 | |
I would be surprised if the Kickers would be happy with as much as it can put out anyways. Just check craigslist for some real PA speakers if you want to do a party right. |
#23 | |
hey i found this laying around some old boxes they where 49.7 ohms average so with 5 i made the 10 ohm network altough they look like 5 watts resistors there is a sharpie next to them for size comparison |
#24 | |
i plan to build some SS15's but my woodwork skills are lame plusi need to get the tools |
#25 | |
Hey, your off then!
![]() I wouldn't bet on the 5W rating, looks more like 2W? Anyway, you don't need a lot of power to do this, even half a Watt would do. A lot of measuring is done with a 1000Ω resistor too. I'm very interested in your used method and results. good luck.
![]() Quote:
#26 |
i keep you posted
just let me get the sub as is still not in my hands brother in law got it on other state he will mail it to me hope dont arrive broke i want to make the measurement |
#27 |
ok subs never arrived so this thread is closed
| In Bass reflex box (vented)-If I make smaller box than what consequences will I have? | eliaselias_0 | Multi-Way | 6 | 3rd January 2011 03:49 PM |
| Dual 15" party speaker | Cal Weldon | Swap Meet | 2 | 15th April 2008 11:28 PM |
| Help on Dual Chamber Reflex box & car audio response Q's please (LONG) | beady | Car Audio | 7 | 6th August 2004 11:57 AM |
| Help on Dual Chamber Reflex box & car audio response Q's please (LONG) | beady | Multi-Way | 0 | 3rd August 2004 10:09 PM |
