ok so this is my first subwoofer build. I got the Peerless 830500 brand new from my mate for $100AU and decided to build myself an enclosure. Ive done countless hours of research and come up with:
60ltr Sealed OR 60ltr Ported Plate amp : Hypex DS4.0 Ive put the figures in winiSD and posted some pics. Basically all i want to know is which way would you go if you were in my shoes. Sealed or Ported? I will make the enclosure so i can have a removable back so i can try sealed or ported. But before i go ahead with the build i would like to know people thoughts and get some feedback. My only worry with the ported design is the group delay. Cheers Mitch. |
#2 |
I run two of these in 60L sealed boxes. I much prefer sealed low Q as I think they blend into a real room much better than ported. In a real room, with real room gain, real music, they are very natural. I don't care at all about special effects.
For a sub, group delay in not relevant. You could built it ported and if you use drain pipe for the port, just get a test plug to seal it. I run an LR4 crossover at 60 Hz using a Parasound 1200 amp. |
#3 |
thanks for the quick reply tvrgeek. Ive had sealed subs in the past and like them better then ported. With sealed i FEEL the bass more and it is more accurate. Ported was less accurate and didnt blend well. But the subs were all different brand wise and size... but like i said, this is my first build so i will be designing the enclosure so i can remove the back and put another on with ports. So ur subs are EQ? just crossed at 60hz?
#4 |
I wound up with no eq. Originally I used a DCX so I could tweak a little, but went back to a simple analog crossover. I spent quit a bit of time working with position and the room. Keeping each sub just behind the main helped a lot. Every room is different. I still have a couple of minor issues but the solution is drastic. ( attic based massive bass trap). I tested it with 6 rolls of insulation piled in the corner. Worked very well but WAF was very low.
#5 | |
Tvrgeek's suggestion is good, built it ported and plug the port when accuracy is most desired, leave it open when you want more shake. The PVC plug is a simple way to do it, though a custom cut hard foam plug can be used for any port shape, a wrap of duct or Gorilla (my favorite) tape makes it easy to pull out. Art |
#6 |
i will be getting the wood cut on friday. It will be 1inch thick mdf. Ill then put it together next week sometime. Ill post pics. Like i said in previous posts, ive designed the enclosure so i can completely remove the back of the enclosure. Ill have 2 backs. 1 plain and the other with the ports. Ill keep everyone up to date with my progress
. Thankyou for your replies.
#7 | |
MLStrand56 |
| Which to choose? | dirkwright | Solid State | 10 | 31st December 2011 09:18 PM |
| Help me choose | integrite07 | Car Audio | 8 | 12th June 2011 08:56 PM |
| what to choose?? | truttne | Full Range | 6 | 15th December 2010 06:22 PM |
| What to choose ? | ToG | Chip Amps | 20 | 16th November 2004 02:36 PM |
| Which would you choose? | Milzie | Multi-Way | 6 | 14th December 2002 02:10 PM |
