Old 13th November 2012, 03:03 PM   #71
tb46 is offline tb46  United States
Nice! Well done!
Oliver
Old 13th November 2012, 04:14 PM   #72
ßart West-VL.'s Avatar
Impressive, congratulations!!
Old 14th November 2012, 04:41 AM   #73
Originally Posted by m R g S r View Post
I know I keep thinking the same thing! I know (from moving it up the stairs) that this thing is huge, but in the pics it looks small
I literally listened to it for 2 mins at a low volume. I'll run some sine waves through it when no one is home and see how she does, maybe add some EQ with the mini dsp. Then I'll throw in a blu ray and crank it up!
It just barely fits that location as if you designed it that way.
Old 22nd November 2012, 10:58 PM   #74
maxo is offline maxo  United States
Wow
masterpiece...
how it sounds !!!
btw, why you choose an 18" driver if most of the times you will not need that SPL's
with a TH with an 8" or 10" you will have enough
im not an expert on subs design but have seen some pretty nice figures with TH boxes
with singles or duals 8" or 10"s
Old 22nd November 2012, 11:07 PM   #75
Thanks!
Well I had 2 12's but they weren't tuned low ebought for HT (which is what this system is strictly used for)
And once I saw this new Dayton driver I really wanted to try it out! For $250 plus two sheets of 18mm Baltic ($130ish) you can't beat this really. Well with some EQ as well to boost the low end roll off from a sealed box. But it's a great setup for the $. For any $ actually even twice that price!
Old 22nd November 2012, 11:10 PM   #76
(Max Drooling)
the more i see this stuff the more i start to dig it
hopefully i will start to butch some wood soon
so, what was your mini DSP parameters
high pass freq (24/48 LR )
at what voltage you limit your box
and what amp you are using to drive it ( 8 or 4 ohms )
Old 23rd November 2012, 08:24 PM   #77
I think I set the high pass at 15hz? With a sealed enclosure its not *as* critical as a horn or BR where excursion increases rapidly. Excursion still rises in the lower octaves but not as rapidly.
I wanted the full 20Hz from this box...at low listening levels. If I was really abusing this, I'd be more careful with the high pass, set limiters in the DSP etc. but as Josh pointed out, this driver has plenty of xmech to play around with, even if Xmax is only 12mm or so.
The amp is pretty powerful, 1500rms at 4 ohms.... clean power? I'm guessing 1000-1200or so with low distortion.
Old 23rd November 2012, 10:06 PM   #78
ic, i wish the minidsp implement a limiter and tha would be the poor mans driverack
Old 24th November 2012, 02:33 AM   #79
They do. They also have a balanced 2x4 board which would work well with pro audio stuff. Check it out!
Old 24th November 2012, 04:31 AM   #80
cant find where the limiter settings are
Ultra compact ported 15" Dayton Ref HO turbodawg Subwoofers 83 16th April 2013 04:04 PM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Dayton Classic 18" DCS-450 - Tapped Horn? dolinux Subwoofers 15 4th December 2009 04:38 AM
T-Line for Dayton Ref 8" (RS225) dunderchief Multi-Way 20 7th November 2006 07:31 AM
Dayton pro 18" woofer w/4" VC rcavictim Multi-Way 8 27th November 2004 03:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
