Will this driver work???
Old 10th October 2012, 06:52 PM   #1
djn is offline djn  United States
djn's Avatar
Default Will this driver work???
Hi All. I have two nice cabs and two plate amps and have been waiting for drivers to fall into my lap. Well, I got two from a friend of mine the other day but even the manufacturer has no data on them. I do have WT3 and here is a screenshot for them. I don't really know how to enterpret WT3 results.
Do you think they will work in my 1 cu ft cabs?
Old 10th October 2012, 06:56 PM   #2
Andrew Eckhardt is offline Andrew Eckhardt  United States
Think you'll have to find Vas before you can determine volume. Unless they are 8's or smaller, probably will need more volume.
Old 10th October 2012, 07:14 PM   #3
djn's Avatar
They are 12" drivers. I'll try to do the weighted VAS thing in WT3. I've never heard that it works well, but it might get me close.
Old 10th October 2012, 07:46 PM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
If you chose the Vas method be sure to correctly calculate the real Vb = Volume of the box with no air leaks - exact the Driver occupied volume.
The added 'mass' method is a much easier to get right and not that prone to 'user' errors that the Vas method is known from.
b
Old 10th October 2012, 07:54 PM   #5
If you're very sure about the net volume you can always measure/calculate Qts by the height and width of the resonant peak and work back to Vas. The boxes already exist so no design there anyway. It might be the F3/Qts you wind up with that matters. You could just pop them in and run a sweep, see if you like the F3 and damping you get.
Old 10th October 2012, 07:57 PM   #6
djn's Avatar
Thanks for your suggestions guys. I was just reading the WT3 lit and it looks like I can mount the driver in the box and get VAS that way. Is that what you were referring too Andrew???
Old 10th October 2012, 08:14 PM   #7
Yeah except the woofer tester will probably keep you from having to make any hand measurements and a page full of calculations.
Old 10th October 2012, 09:05 PM   #8
djn's Avatar
Cool. I like that.
Will this driver work???Hide this!Advertise here!
Will and Aikido Driver Stage work? bluegti Tubes / Valves 4 3rd December 2009 11:02 AM
Omnidirectional midrange driver - will it work? el`Ol Planars & Exotics 3 19th November 2007 08:00 AM
Will this MOSFET-driver circuit work? Danko Power Supplies 7 24th June 2005 02:09 PM
Would this driver arrangment work? Hybrid fourdoor Multi-Way 6 10th July 2003 02:09 PM
would this driver combo work well? trespasser_guy Multi-Way 20 1st January 2003 11:49 PM
Copyright ©1999-2017 diyAudio
