Peerless woofers Push-Pull Cabinet Design. - Page 2 - diyAudio
Old 10th October 2012, 08:19 AM   #11
Originally Posted by legomedu07 View Post
I haven´t found them on ebay. By the way, where to buy those drivers is not my main problem... I just want to know how to build the cabinet...
They are on ebay UK right now, the reason I mention it is that they are half the Wilmslow price, I just bought a pair.
Old 10th October 2012, 09:42 AM   #12
Originally Posted by doubtingthomas View Post
Check ebay for these drivers.
I have already seen the loudspeakers on ebay but, T-S parameters are completely different. It seems to be the same driver, with the same reference name and everything, but the parameters are different.
Take a look to the comparision picture I made...
How is possible so different parameters in the "same" model? It is just an ebay mistake or is it possible these differences?¿
ebay Peerless XLS10 P830452
Wilmslow Peerless XLS 830452
Maybe the P before the "830452" means that these are different from the others...
Old 10th October 2012, 11:19 AM   #13
Maybe, how about checking Tympani?
Old 10th October 2012, 11:27 AM   #14
Sorry, that should be Tymphany and they refer to a P830452.
Old 10th October 2012, 11:33 AM   #15
you are right... tymphany show the same parameters than ebay.
Is Wilsmlow parameters fake or is it a different driver?¿
I have opened a new thread for not contaminating this thread.
Different features for "Peerles XLS10 830452"
Old 10th October 2012, 01:00 PM   #16
I imagine Tymphani could be helpfull if you email them.
Old 10th October 2012, 01:54 PM   #17
5th element's Avatar
Drivers do go through different versions without the part numbers changing. The two 452s are still pretty similar but do show some small differences.
Both sets of parameters are correct, now as to which parameters belong to your driver? That's up for you and the supplier of you drivers to decide. An email to Tymphany wouldn't hurt.
a) Is it true that these drivers cant handle frequencies below the frequency which makes impedance maximum?
No.
b) Which is the minimum frequency my simulated boxes could play¿?
As low as you want. What determines how loud the sub will play for a given frequency is it's rated xmax and power handling.
c) do these parameters depend on the shape of the box? I mean, will these parameters ( impedance, SPL, cone excursion ) change depending on the shape of the box?
Yes, but not enough to be significant in this case.
I wont build sealed boxes... I will build these special push pull subwoofers cabinet.
There's nothing special about a push-pull driver arrangement, what you're building is a sealed box.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 26th October 2012, 06:32 PM   #18
Asdonk is offline Asdonk  Netherlands
I want to build this PUsh Pull subwoofer.
I will be using the Scanspeak 30wT4558 driver which has almost the same
T&S like the peerless 830517 (xxls12)
Ralf
Old 27th October 2012, 01:35 AM   #19
tvrgeek is offline tvrgeek  United States
Volume of box.
Sim is a starting point. Prototype.
Of course drivers can "handle" below their impedance peak. How much is the question.
Old 27th October 2012, 10:33 PM   #20
these drivers look amazing asdonk... just remember that you will need an amplifier capable of driving 2 ohms... ( since your speakers are 4ohms each )
Differential push-pull design question Tyimo Tubes / Valves 4 15th January 2010 08:05 PM
push-pull design nukaidee Multi-Way 31 9th May 2009 10:18 AM
single cabinet...dual rlp-15's...push pull? kramskoi Subwoofers 1 26th March 2006 12:34 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
833 push pull design help sickss Tubes / Valves 19 7th March 2005 04:25 PM
Copyright ©1999-2017 diyAudio
