Can a larger sealed box be detrimental? - diyAudio
Old 4th October 2012, 02:47 AM   #1
Default Can a larger sealed box be detrimental?
Going to put a pair of Tempest X2-15" in sealed boxes. Manufacturer indicates that a larger sealed box is a better sealed box...
It seems to make sense for me, to put them in ~13 cu. ft. boxes, for various logistical reasons (not sound quality related). Manufacturer does not say what happens beyond 8 cu. ft.
Is there any detrimental effect due to putting a sub in a larger sealed box?
Thank you.
Old 4th October 2012, 03:03 AM   #2
diyAudio Member RIP
A pair in a 13cuft box seems fair enough for a 9 cuft Vas driver.
Qbox will be about 0.65, a very well stuffed box about 0.6.
-3dB around 33 Hz.
rgds, sreten.
Old 4th October 2012, 03:12 AM   #3
Thank you sreten. I meant two subs, each in a ~13 cu. ft. sealed cabinet.
Old 4th October 2012, 03:21 AM   #4
diyAudio Member RIP
You will gain next to nothing by going over 9 cuft per driver.
But then again if 13 cuft is convenient, there is nothing lost.
rgds, sreten.
Old 4th October 2012, 03:53 AM   #5
Einric is offline Einric  United States
Einric's Avatar
You may gain sloppy bass with a large cabinet.
The sealed box acts like a spring pulling back on the cone (or pushing on the in-swing).
Without that resistive pressure both directions you are relying more on the driver's suspension and can run into damaging the suspension system on the driver.
Old 4th October 2012, 02:44 PM   #6
Josephjcole's Avatar
Einric
I believe this is incorrect. Drivers in an oversized sealed enclosure are considered over damped. The "air spring" inside a sealed enclosure can help to control excursion, but does prevent it from being "sloppy".
Shelf bracing detrimental for SPL? buggsson Subwoofers 4 30th September 2008 12:57 AM
Sub Rattle Sealed Box thefish Subwoofers 12 14th February 2007 01:54 AM
Digital Attenuation, how much detrimental? SKK Digital Source 3 4th February 2007 01:22 PM
Larger box for sealed OK? mazeroth Multi-Way 3 8th April 2005 07:58 AM
Copyright ©1999-2017 diyAudio
