best budget woofer for 1 cuft sealed sub?
Old 1st October 2012, 12:22 AM   #11
4Torr is offline 4Torr  United States
Beware of car audio specs. I punched in the T/S parameters from the owner's manual and the calculated efficiency is 81.5 db spl/watt/meter and 85.4 db/2.83v/meter sensitivity. Hoffman's Iron Law cannot be broken.
Old 1st October 2012, 01:41 PM   #12
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Thanks 4Torr for your great advice. I've also just noticed the Monacor Sam-2 active 2.1 module on Blue Aran
but not sure if the plate amp actually powers the satellites? Maybe it requires a separate amp for this
extract from manual
"The high-quality active high-pass filter of the SAM-2 with versatile adjustments can conveniently be used as a bass relief of the main speakers and for optimising the sound. However, a regulated pre-amplifier output (Pre Out) is required for this. This kind of output is partly present at high-quality separable full amplifiers (Pre Out/Main In) or automatically provided by pre-amplifier/power amplifier combinations or when using mixers."
Old 1st October 2012, 05:53 PM   #13
The instruction manual says it's a bass amp with a 2 way electronic crossover. You must provide the satellite amp.
http://www.monacor.de/de/FLE/SAM2.pdf
Old 1st October 2012, 11:10 PM   #14
Here's an odd driver - it has a very high qts - on winisd produced some interesting results if inputting the 4 ohm parameters and 55 litres sealed Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories
best budget woofer for 1 cuft sealed sub?Hide this!Advertise here!
woofer in sealed box Professor smith Multi-Way 4 20th November 2011 06:55 PM
7" woofer for 2 way sealed monitor audiothings Multi-Way 34 16th January 2011 08:42 PM
Woofer choice in 2-way sealed cabinet tinos5601 Multi-Way 1 13th March 2007 05:55 AM
how big of a sealed box will this woofer need ? zuki Subwoofers 7 2nd May 2006 07:16 AM
sealed woofer box patriz Multi-Way 0 2nd April 2002 10:06 PM
Copyright ©1999-2017 diyAudio
