ideal box for a 12" subwoofer?
Old 27th September 2012, 07:46 PM   #1
realflow100 is offline realflow100  United States
Default ideal box for a 12" subwoofer?
what kind of box should I have? I have a 12 inch DUAL
subwoofer in a fisher stv-6558 box that someone gave to me
It sounds good but the low end bass is almost non existent..
there is a lot of bass at slightly higher frequencies almost too much at 45hz+
but under 40hz the bass just drops out to nothing almost.
is there some kind of box that would be better or have deeper bass for my 12"?
or some kind of box under 50$
I want the box to be ported or some kind of simple t line is there any place i can get one specifically designed for subwoofers?
Old 27th September 2012, 10:27 PM   #2
tvrgeek is offline tvrgeek  United States
The ideal box is one that works for you. I prefer sealed subs with low Q as I feel they blend into the room easier. Others want the very maximum bass extension and do ported. My wife would say ideal was not ugly.
You design the box yourself. That is what DIY is all about. $50 will get you enough 3/4 inch plywood to do very well indeed.
Process: You need the T/S parameters for your driver. Published is you are lucky, or measure like we all do.
Then use a simulation tool as no one has a coppy of White's tables from Speaker Builder any more and you don't want to do the math from Dick Small's papers in AES. I use WInISL. Free.
You then can have it do a theoretical perfect box, and play with the size and tuning to see what happens. Then just cut up the plywood and glue it together. Nothing magic, just engineering. T-lines are a very advanced subject and not very useful for subs IMHO. Sealed is easiest and most forgiving, ported offers more tuning options.
What makes you think a different box will make your drivers go lower? The box is not magic, it just enables the driver to do what it was designed to do.
Old 28th September 2012, 12:36 AM   #3
I have a very weird custom amplifier (home made) and certain frequencies play better in a different box (when i cover the port on my box the subwoofer acts differently and different frequencies play better than others.. and some frequencies are harder for the amplifier to play when i take my hand off of the port) and so I wanted a box where both freqencies play good.
it puts out at least 25-50 watts to power my subwoofer because it easily drives it a full inch or more at certain frequencies.) certain frequencies are harder to play in different boxes
(the amplifier has a harder time driving different frequencies than others in different boxes)
Old 29th September 2012, 12:37 AM   #4
All you are doing is seeing what changes in the box tuning does. I seriously doubt the amp knows the difference. If it does, time to build a new amp.
Seriously, I think you need to do a little background reading to get the basics of what a box does and why. You might also do a little reading on how amps work, or don't. Otherwise you will be chasing magic. Speakers are not magic, they are engineering. What you will learn is if the box does not properly control the driver at their resonance, then it will flop in the breeze at resonance. That is what you are seeing. It is not the amp, it is an incorrectly tuned box and driver system.
Old 29th September 2012, 01:37 AM   #5
Etocynned is offline Etocynned
So if you have a model # you can look up its thiele small parameters and design and build a box. If your really wanting to jump into the rabbit hole get the woofer tester from parts express, measure the TS parameters, dump them into a modeling software, winisd eg. And then make sawdust!
rinse and repeat till youve enough boxes to live in or satisfaction plasters a silly grin on your face!
Altec Lansig computer speaker amp, Paradigm atomss, Altec computer sub, Windows PC source
Old 29th September 2012, 02:57 AM   #6
sorry I don't own a powerdrill
all I've got is butter knifes.
what I mean to say is I would much rather simply buy a decent ported box that's simple and good enough.. it doesn't have to be perfect... just better than what it is now..
Old 29th September 2012, 05:10 PM   #7
What you keep missing is the box is designed specifically for the driver. There is no such thing as generic good enough boxes.
It sounds like you should just buy a kit off PE or used off e-bay. DIY means do it yourself. Design and build.
Old 30th September 2012, 11:48 AM   #8
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
well, I do know how it feels, finding something strange, and you just get the urge to use it, somehow
hmm, maybe it just needs EQ
so maybe you need a plateamp, instead of another box
Old 30th September 2012, 12:39 PM   #9
Trying to EQ your way out of a miss-matched driver and box is looking for problems. Come on Tinitus, you know better than that!
Old 1st October 2012, 12:09 AM   #10
nope
he would have a good amp that could be used for a better sub project later on, instead of yet another useless box
ideal box for a 12" subwoofer?Hide this!Advertise here!
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 01:11 PM
Help wanted building an optimal sealed box for a single 12" subwoofer. nexttothemoon Subwoofers 3 4th January 2010 05:47 AM
12'' Subwoofer box design marinbnm Subwoofers 4 14th November 2007 08:44 PM
FS: Subwoofer Box for 12" Speakers 2skys1imit3 Swap Meet 0 19th June 2007 06:29 PM
