cable gauge to build Neutrik Speakon
Old 26th September 2012, 08:11 AM   #1
dtses is offline dtses
Default cable gauge to build Neutrik Speakon
cheers!
a quick question. I've got a plug NL4FX and need 1.5-2m of cable to connect my REL Quake to the amp. Is there any point using OFC shielded cable for this purpose? Also what is the minimum gauge to use, will 2x0.25mm2 (AWG23) be enough?
Old 26th September 2012, 08:41 AM   #2
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by dtses View Post
cheers!
Shielded cable is not needed, and may present problems with speaker cable.
AWG23 is extremely whimpy for sub use (alright for mic cable at 600 ohms) unless you are using 64 ohm speakers, use a minimum of 16/14 AWG at 4 ohms for 2 meters if you care about damping factor.
If you like your subs to go "duhhh duhhh duhh" use any strand of wire you find around :^).
If you have difficulties wiring proper size cable into a small connector, reduce the cable size at the junction point.
Old 26th September 2012, 11:35 AM   #3
ianpengelly is offline ianpengelly  United Kingdom
ianpengelly's Avatar
IIRC the REL speakon input is a high impediance input design to allow a speaker level connection to drive the internal amp circuit of the sub. Very little current will pass through this connection, so the speaker wire you have suggested should be fine and I wouldn't worry about it being shielded.
Old 26th September 2012, 12:53 PM   #4
thanks for prompt replies!
Now I'm confused completely
Perhaps the best way would be to try this ofc shielded mic cable vs some simple thich one.
Should I aim for minimal noise from REL once Neutrik plug is connected and other ends are bare?
Old 26th September 2012, 01:09 PM   #5
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
No, that is XLR; speakon is to deliver current to the drivers. You need the same gauge as you would normaly use for speaker connections.
vac
All atoms to the left!
Old 26th September 2012, 01:49 PM   #6
cheers!
Old 26th September 2012, 05:50 PM   #7
mattlong8 is offline mattlong8  United States
mattlong8's Avatar
In the US the maximum type of cable that will fit in that connector easily is the 12/4 SJOOW. But if you bore out the strain relief nut a bit and remove the u shaped metal tangs held in by the screws one can fit the 10/4 SJOOW. This is not a fast process bear in mind. The "J"version(sjoow) as opposed to SOOW is rated at 300V as opposed to 600V. Local regulations regarding the different use of such cables varies and often times there is no standard for their "low voltage" use as we intend. To get a little more flex the cable class "SC" or stage cable is quite nice. I believe it has more braids per individual wire. Please note that these are US standards and I have no knowledge if they apply elsewhere but I'm sure a bit of research could yield a corresponding cable in your country.
-Matt
Old 27th September 2012, 07:14 AM   #8
it's pretty clear now with the cable! thank you!
Just curious, if I use speaker terminals of my amp, does it mean that REL uses only preamp section?
Also as far as I've understood connecting sub via high level input makes additional load for the amp, isn't it?
Old 28th September 2012, 01:19 AM   #9
PAGS is offline PAGS  United States
vac
You may be right, but the Speakon cable connection provided by REL with a new subwoofer would seem to contradict this theory. The cable is 10 meters long - that's almost 35 feet! It has the Neutik Speakon connector on one end, which connects to the sub, and three bare wire connections on the other end. The bare wires connect to the L and R amplifier speaker terminals. The thickness of the individual wires appears to be smaller than 16 gauge (18 maybe?). According to the REL manual using the Speakon connection "is the preferred method of connecting a REL to any system."
REL is considered to be a higher end manufacturer of hifi stuff, and the company's not shy about putting big price tags on the equipment it sells. I'm no sound engineer, but I believe that if there were any meaningful signal degradation associated with the thin-wired, long cable Speakon connection the company wouldn't be selling it, or at least it wouldn't be promoting it as the "preferred method" of connection.
My non-technical newbie comments, for what they're worth.
Old 28th September 2012, 03:24 AM   #10
JapanDave is offline JapanDave  Japan
-Matt
I got 10 gauge to fit without taking the u shaped metal tangs. It was an effort, but I eventually got in.
cable gauge to build Neutrik SpeakonHide this!Advertise here!
4 - .7082 mH 12 gauge inductors -- $8 for one ___ 1 mH - 18 gauge -- 2 USD and others Jimmy154 Swap Meet 11 28th May 2012 09:27 PM
Sub plate amp with Neutrik Speakon input? D_Dubya Subwoofers 1 15th July 2009 02:02 PM
Impedence from Neutrik SpeakOn Nicholas1520 Solid State 1 14th April 2007 04:16 PM
Neutrik Speakon connectors timo Multi-Way 7 27th August 2002 05:47 PM
