cable gauge to build Neutrik Speakon - Page 2 - diyAudio
Old 28th September 2012, 11:42 AM   #11
I use 4mm^2 cable for my speakons, fits nicely but I have no idea what size that is in AWG.
Old 28th September 2012, 01:15 PM   #12
the cable is ready, I used AWG17 copper, 2m long. Not sure if it should behave so, but when the amp is turned off, REL reproduce some small ~30Hz hum (high level regulator is in the middle). Should it be so or should I try shielded one?
Old 28th September 2012, 01:17 PM   #13
here is a good link. Seems to me AWG11
Old 28th September 2012, 04:25 PM   #14
GM is online now GM  United States
GM's Avatar
Originally Posted by PAGS View Post
The thickness of the individual wires appears to be smaller than 16 gauge (18 maybe?).
Wire size is all about voltage drop over distance, so an insignificantly low drop at 100 W/100k ohms/35 ft = 16 ga, but 18 ga would still be very low, so a good guess since manufacturers will 'cut corners' cost wise wherever practical. 8 ft [~2 m] = 22-23 ga.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd June 2013, 02:37 PM   #15
Originally Posted by ianpengelly View Post
IIRC the REL speakon input is a high impediance input design to allow a speaker level connection to drive the internal amp circuit of the sub. Very little current will pass through this connection, so the speaker wire you have suggested should be fine and I wouldn't worry about it being shielded.
^^^This. The REL input is indeed a high impedance input and as such carries very little current to the sub. It is used as an input source to the amp on the sub. I don't think I would use shielded, due to additional capacitance.
Originally Posted by vacuphile View Post
No, that is XLR; speakon is to deliver current to the drivers. You need the same gauge as you would normaly use for speaker connections.
vac
Sorry, but it is indeed a Neutrik Speakon. Completely different from an XLR. It does not need to be similar gauge as a speaker wire.
Originally Posted by dtses View Post
it's pretty clear now with the cable! thank you!
Just curious, if I use speaker terminals of my amp, does it mean that REL uses only preamp section?
Also as far as I've understood connecting sub via high level input makes additional load for the amp, isn't it?
It will not create any significant change to the load on the amp. One thing to note, though is I have found that it is particularly sensitive to picking up induced signals. Do not leave excess coiled up as the coil will act as an antenna. Keep it away from power cords where possible.
If you do decide to change the cable, it is very simple as the neutrik connector is very easy to take apart and there are simple screw terminals. These connectors are designed to carry line voltage at low frequency and as such are not very fussy. They are used as highly reliable power connectors on a lot of professional gear.
Sorry to come on strong as a first post!!!
Old 22nd June 2013, 05:57 PM   #16
chris661's Avatar
+1 to everything BayouTiger just posted.
4 - .7082 mH 12 gauge inductors -- $8 for one ___ 1 mH - 18 gauge -- 2 USD and others Jimmy154 Swap Meet 11 28th May 2012 10:27 PM
Sub plate amp with Neutrik Speakon input? D_Dubya Subwoofers 1 15th July 2009 03:02 PM
Impedence from Neutrik SpeakOn Nicholas1520 Solid State 1 14th April 2007 05:16 PM
Neutrik Speakon connectors timo Multi-Way 7 27th August 2002 06:47 PM
Copyright 1999-2017 diyAudio
