I just built a stereo pair of sealed subwoofer boxes loaded with Aura 1808 woofers. I'd love to hear your suggestion for good EQ options? Here are my requirements:
* True stereo, not summed outputs (I know, most say bass is not directional below 100 Hz and most recordings are mono in that range anyway, but I want the flexibility to adjust each separately and keep the stereo, stereo) * EQ range from 20 Hz to 100 Hz or slightly higher (if analog, I don't want EQ covering 20Hz to 20k Hz) * I'd prefer an analog EQ for this simple task rather than going from D>A>D>A, but I'm open to DSP as long as it's self-contained or works on a Mac. I'll only use the DSP for the subwoofers, and don't need a crossover or other options, only EQ (I'm sure DEQX makes a nice unit, but it would be overkill just to EQ bass!). Thanks! |
#2 |
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 | |
also is not a good idea to tweak the sub at anytime subs are set and forget specially on home enviroments it is for your home setup ? like for movies and or music ? what you need to do is to sweep your room and look for modes if you want to eq, i am pretty sure that you got some bad acoustics the best way to deal with peaks and valleys on the sub audio spectrum is with bass traps, the more controlled your room audio wise the more tight and punchy you will hear your bass also as you said, bass is non directional, you dont really want to have stereo subs, but you already built them, what you can do is to stack them side to side to have more output out of them, instead of put them on left and right corners with an ecm8000 and some free software you can sweep you room and graph the freq response of it, the flatter the better but as i said, you need bass traps to correct your peak and valleys, you cant correct that with EQ, you will only overwork and damage your sub drivers if you boost too much on the bands There is plenty of info on the forums on what software they use to sweep a room and how they do it Max. |
#4 |
Thanks for the suggestion, GM...I'll look into the Anti-Mode. The Behringer DSP1124P looks like another option at a no-brainer price going for $50 on ebay.
#5 |
Yeah, it was very popular some years ago, but didn't mention it since I thought it was long out of production.
GM
#6 |
Max - I'm positive that I have bad room acoustics. My system is in the basement, so I'm dealing with plywood over concrete walls and concrete subfloor. It's also an odd "L" shape. I think it's beyond what I could do with some bass traps. I've run sweeps and everything is really flat except for my subwoofer section—that's why I'm looking to EQ. Why do you say it's not a good idea to EQ subs?
#7 | |
they must be pretty flat , unless you have changes some variable drastically but if not, and your cabs are build within the specs your problem is not to EQ your cabs but to tame the modes in your room at what freq are you low passing your subs ? |
#8 |
GM - I emailed tech support for Anti-Mode and they said that the outputs are summed, so it looks like the Behringer (despite mixed opinions on the brand/company) is the better choice for my purpose.
#9 |
Several difficult to address considerations. Might as well make life easier with a mixed bass signal to start with. Two subs (and with the same bass signal) is a very good idea - providing you are prepared to locate them in heterogeneous locations.
There is no way to separate speaker, location, and room... all the sound ends up with your listening position ears as the criterion. Far from flat and the bass of a room is not easy to control very much. I think, like concert halls, you should try to start with speakers and room that are pretty good (in dimensions and furnishings) and go from there. (I often howl with laughter seeing pictures of some bare-bones living rooms containing some state-of-the-DIY speaker systems which have to sound awful there.) No way to diddle with all the peaks and valleys. For my taste, nothing more intuitive than a parametric equalizer (or DSP equivalent) where you choose maybe two bad frequencies and then add or subtract and choose the width of the correction. (The outputs near the top and bottom of the sub range are handled in the pre-amp and cross-over stages.) Anything more is just making yourself crazy. Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 Last edited by bentoronto; 27th September 2012 at 12:14 AM. |
#10 | |
GM
| FS: DBX 1231 31 Band Stereo EQ | matevana | Swap Meet | 1 | 23rd October 2011 01:55 PM |
| Subwoofer EQ | Buzzy | Subwoofers | 0 | 23rd September 2007 04:32 AM |
| Cheap Pro Audio Crossovers and EQ for home stereo? | santiu | Multi-Way | 1 | 4th December 2005 12:15 PM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 03:19 PM |
| Best way to EQ subwoofer | The Paulinator | Subwoofers | 3 | 18th December 2004 05:19 AM |
