can you spice up a cheap sub ?
Old 26th September 2012, 08:16 PM   #31
maxo is offline maxo  United States
Originally Posted by turbodawg View Post
I was just going to say that you could do better for $129:
Amazon.com: JBL GT5-15 15-Inch Single-Voice-Coil Subwoofer: Car Electronics
http://static.highspeedbackbone.net/...fer%20Data.pdf
Find some free wood, etc......
ok so the driver looks like is for car subs , can i fit it in an SS15 ?
or on what enclosure
Old 26th September 2012, 08:43 PM   #32
turbodawg is offline turbodawg
The JBL recommended enclosure in the PDF I linked to.
Old 26th September 2012, 08:57 PM   #33
\ohhh i c them now
hey , i liked the ported design, can we got something more "loud"
that driver only gets up to 95db's at the highest wattage of the driver
but i think if we want more db's out we need a bigger power driver and a folded horn box, mmmm
can we get a poor man's SS15 ?
using 1/2 wood and some lest costly driver than the 299 bucks ones they are using
maybe a 120 bucks driver
and if i want to make the JBL ported box, i will need to hit the inside volume right ? doesnt matter if it is a cube or a rectangle shaped box, as long as i follow up the volume spec and the port size and lenght of the tube
Old 26th September 2012, 09:01 PM   #34
Sorry I can't help you. Good luck.
Old 26th September 2012, 09:18 PM   #35
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Don't deviate from the SS15 plans or driver selection. If you do it right it'll be worth the effort/$$$.
Dan
Old 26th September 2012, 09:21 PM   #36
Ayeee
hey man
what is the lightest driver you can put in there i dont care if loose a couple of dbs but i want to minimize weight
can i put those very light magnet ones ( i mean that are in the approved official list )
and can i use 1/2 birch with internal brasings
http://www.homedepot.com/h_d1/N-5yc1...1#.UGNkblHHX7Y
Old 26th September 2012, 09:33 PM   #37
NEO Dan's Avatar
Eminence Kappalite 3015LF Neo 15" Driver will work but the lightness is gonna cost you ~$100...
Dan
Old 26th September 2012, 09:35 PM   #38
ic, and what is the least expensive one that can fit insde the SS15
Old 5th October 2012, 09:16 PM   #39
Old 5th October 2012, 10:56 PM   #40
NEO Dan's Avatar
I think the answer is in JBell's thread...
Dan
can you spice up a cheap sub ?Hide this!Advertise here!
Need help with OB design - cheap, cheap, cheap djn Multi-Way 38 30th May 2010 07:26 AM
Free Spice Or Cheap Spice Simulator-Where To Start? kelticwizard Everything Else 29 15th February 2007 02:38 AM
Scosche SPL meter: Cheap find with potential, or cheap junk? theAnonymous1 Everything Else 5 11th October 2006 04:40 AM
