#21 | |
Very cool design- got a link? Also, the woofer section should be braced from mounting to mounting- this sub could take advantage of force cancellation.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#22 |
I know people have purchased this back here a few months back
Amazon.com: Infinity Kappa 120.09W 12" Subwoofer: Car Electronics and this could be available Amazon.com: Infinity Reference 1262w 12-Inch 1200-watt High-Performance Subwoofer (Dual Voice Coil): Car Electronics Visiting the shop tomorrow to find out. |
#23 |
In the end, displacement volume is the key to low and loud base. And the 10" Dayton woofer got +-14mm of linear excursion. With a surface area of 350cm² x 2 subs you can move a lot of air (as much as with one good 15" woofer or with two casual 12" ones).
I recommend seal boxes, because they don't release as much energy into the room as a 20hz ported design would do. Therefor your room is excited less (room modes again) and the bass sounds way clearer. And consider, your small room won't allow you to produce any frequencies below ~25hz. So don't waste money and acoustic energy by trying to build a 25hz subwoofer. 30hz is all you need, trust me (and you can still add a few hertz by equalizing the sub) I think dual subwoofer are a waste of possibilities. You can't cancel (or at least reduce) room modes because there is only one position. And in my opinion force cancellation is widely overestimated. the vibrations produced by subs are negligible / don't interfer with the music. Just take a look at all the professional studio subwoofer. There is not one using force cancellation. And concerning these infnity speaker, i can't find any proper spec sheet. I won't buy anything that is sold without at least the basic tsp. Last edited by Samyk; 20th September 2012 at 05:44 PM. |
#24 |
I'll have to hunt for the link; made 5 of them (20 woofers).
Here are some of the pics, they are all the same, but 2 of the builds were single fold. The $8 woofer were a buy out/gone, but I think they will be back. The page on right is available.....someone would have to check the design. **Might find the 299114 on ebay, etc. |
#25 | |
#26 |
Just remembered. I bought some Kapa's several years ago. They did have specs. When I measured them, they were so far off, I sent them back. 20% I'll buy. 100% no.
#27 |
I don't think I'd try this with store bought speakers....
#28 |
Yes of course the Peerless XXLS is a great driver, but you still have to consider the price limit of ShaQBlogs. And even if the XXLS got lower distortions while doing high excursion, the two Dayton will be stressed less because of the higher over all displacement volume compared to one XXLS. And ShaQBlogs can't afford two of them.
I could write a lot more, but due to my limited language capabilities concerning technical English i would just take too much time. And tvrgeek, your example is exactly the reason why no one should by cheap stuff. You get what you pay for. In Germany we have a saying: If you buy it cheap, you pay twice. I think the daytons are well priced but not cheap and one of the best options for the limited budget of ShaQBlogs. And before forgetting it, remeber buying the 8ohm version if you want to use poth driver in parallel. Otherwise the impedance will be two low for most of the amps. Last edited by Samyk; 20th September 2012 at 10:14 PM. |
#29 | ||
If this goes better than what I expect then maybe will upgrade later. Quote:
#30 |
| 3 years worth of DIY Madness (somebody Help me) | sumsound | Multi-Way | 15 | 24th November 2008 04:29 AM |
| DIY Heil's, worth a try? | ak_47_boy | Planars & Exotics | 2 | 29th January 2007 04:40 PM |
| Are these DIY planars worth buying? I have to decide within two hours! | Spasticteapot | Planars & Exotics | 4 | 30th July 2006 08:20 PM |
| DIY DACs VS Commercial stuff .. really worth it? | JinMTVT | Digital Source | 16 | 24th November 2005 02:54 PM |
| Any good DIY parts shops in Dallas/Ft Worth? | Hybrid fourdoor | Parts | 1 | 22nd October 2003 11:51 PM |
