Ultra compact ported 15" Dayton Ref HO - Page 9 - diyAudio
Old 7th April 2013, 02:32 PM   #81
Got the system out yesterday for an outdoor party/bbq of about 300+ people. Had a dance area of about 30x40 feet with a wooden platform 12x12 in the middle. About 50-100 people dancing. Sounded great, tons of compliments on the quality of sound. Had a dj play though them and had to hold him back from over driving the subs, was getting into the clip lights on the 6000 but didn't get too far past x-max on the drivers. Pushed the tops pretty hard and got the adcom warm. Was relatively cool out so there didn't seem to be any heat problems. Ran it all off a honda eu2000i generator (~13.5 amp rated), had the sub amp go red twice and blink off for a split second for what I'm guessing was maxing out the generator and not being able to pull enough current. Going to play another party next weekend in a 30x30 ft quasi-basement room.
Old 7th April 2013, 02:36 PM   #82
Nice glad they enjoyed your hard work!
I just read a good review on the inuke6000 amp. I'll look for it now, it produced good power in 8ohms, 4ohms it started to sweat
Old 8th April 2013, 03:42 PM   #83
Thanks! There is a very comprehensive review and bench test of the nu6000 on speakerplans forums. It's (more than) enough for all but the largest subwoofers.
Old 16th April 2013, 04:04 PM   #84
Ran the system again this past weekend in a large room, measured 28.5x22.5x10ft, concrete floor, wood walls, glass doors on far side and 6x10ft opening to another room on the side. Subs/tops had to be placed in front of a stage about 8 ft out from the back wall and against the side walls. Needed to use double sided tape to keep the subs from walking on the concrete floor, even though they have rubber feet and are about 90lb total with the tops/poles, and had to strap the poles to keep them from turning.
Ran them with about +3db Q3 boost @ 35 hz (tuning) and +5db Q2 boost around 110 hz, LP 190hz 4th order, HP 26hz 8th order. Also set limiter at -1db and seemed to be running into it with the kick due to the boost being so high. It kept the woofer from over excursion at lower frequences, but will tweak further.
Hit about 110db sustained with 114db peaks when briefly metered at the end of sound check. The 35hz boost seemed to work well with the room nodes and give a nice smooth low end fill and ample bass presence without being one-note sounding. Many compliments about the sound, including from the band, who had their own PA gear.
Old 25th October 2013, 07:37 AM   #85
Interesting thread. Nice work, nice information.
Cheers!
Old 25th October 2013, 02:15 PM   #86
Cheers!
Thanks!!!
Old 9th November 2013, 09:58 PM   #87
I have a 15" Dayton, the same one used in this design, if anyone is interested. It won't fit in my new car .
Old 14th September 2016, 07:32 PM   #88
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I saw you mention elsewhere you switched to B&C drivers, what's up with that?
Dan
Old 14th September 2016, 11:14 PM   #89
An unattended DJ with amp limiters that weren't set conservatively enough torched the HO's a few years ago. Replaced them with the 15TBW100-4 (4 ohm version). A hair less low end, more kick. I'm considering weighting the cone actually.
THAM15 - a compact 15" tapped horn martinsson Subwoofers 421 Yesterday 09:18 AM
Compact Dayton Titanic 15" Offset Horn Design vnwhite Subwoofers 1 30th July 2012 11:25 AM
Pair of Dayton Reference HO 12" Relax Swap Meet 2 8th February 2007 03:59 AM
Compact 15" sub - BMS or Precision Devices? DIAR Subwoofers 7 4th January 2007 04:06 PM
T-Line for Dayton Ref 8" (RS225) dunderchief Multi-Way 20 7th November 2006 07:31 AM
Copyright 1999-2017 diyAudio
