#11 |
Here's another thread I got ideas from, the BMS driver used is actually pretty compareable in sensitivity to the 15" HO dayton in the models, if I recall correctly, however the 12" ho was 2-3 db less sensitive. The slight rise to 40hz is part of the design strategy, to get better output from a small box.
Q12 12" Sub - Speakerplans.com Forums - Page 1 |
#12 |
Well I bought the mains for the system, Peavey Impulse 100, at a good price. Decent quality, sound, size, weight, and resale value. 96 db/w/m sensitive on the spec sheet, should get loud enough off 75w battery powered and I have a nice 200w per channel adcom to drive them for AC use.
I calc 117.7 db nominal with 2 speakers @ 1m 75w. The 15" HO sims at 118 db from 400w in winisd, 39hz f3. For AC use the adcom drives the pair of mains to 122db nom, and a pair of subs 800w each with one plugged port (~26.5 hz tune) hits 120 db nom with a 29hz f3 (add room gain as applicable, and ports can be unplugged for more gain as needed). Am I on the right track here? Time to get serious about a sub or two. Last edited by turbodawg; 19th September 2012 at 01:11 AM. |
#13 | |
#14 |
#15 | |
#16 |
I'm pretty sure a 5" round port should be fine. It's under 100 ft/sec in winsid with 800, and under xmax. We're only talking about a ~30hz f3, people get these down to 20hz all the time. The small box is a factor.
#17 |
Btw if you want to come down one weekend to test the cabinet outdoors that I have built with the Dayton Ref HO 15 feel free...I have plenty of amp power available
this is copied from my install thread on diyma... Quote:
#18 |
Not much I can do about it, these are the biggest boxes I can fit, and they are about as efficient as any other BR box I could come up with.
#19 | |
#20 |
So I've started to flesh out a box design, no plans yet but here's what I'm thinking.
- 22x19x16 inches external. - Woofer on the 22x16 face - 16x16 baffle offset to side, recessed 1.5" inwards - 1/4" wood on baffle out to perimeter of box, 1/2" wood inside that to support grille - 2 x 5" x 24" ports on same face, outside grille/woofer baffle - PVC drain pipe ports with long 90 degree - No port flares, for simplicity - Thin aluminum strapping to hold ports in place - Slat bracing as needed on panels - 1/2" birch plywood - Internally coated with rubber roofing mastic - no filling - thin, large area rubber feet - pole mount for main speaker on side - intended to be placed on it's side - target weight under 60 lb w/driver Your thoughts? Also looking at pro sub amps, what do you think about the QSC GX5 at 700w 4 ohms vs. GX7 at 1000w 4ohms? It's nominally a 1.5 db difference for a $200 price jump....... Last edited by turbodawg; 21st September 2012 at 01:34 AM. |
| THAM15 - a compact 15" tapped horn | martinsson | Subwoofers | 285 | 7th May 2013 06:34 PM |
| Compact Dayton Titanic 15" Offset Horn Design | vnwhite | Subwoofers | 1 | 30th July 2012 11:25 AM |
| Pair of Dayton Reference HO 12" | Relax | Swap Meet | 2 | 8th February 2007 03:59 AM |
| Compact 15" sub - BMS or Precision Devices? | DIAR | Subwoofers | 7 | 4th January 2007 04:06 PM |
| T-Line for Dayton Ref 8" (RS225) | dunderchief | Multi-Way | 20 | 7th November 2006 07:31 AM |
