Starting a project of bringing my JBL 12" 2214H's back to life in my home system. What size and type of cabinet to build? Of course, my goal is going as low as I can go. Room size, is not a factor they can be big if they need to be. Using a receiver a Pioneer DSX-914 at 110 watts. Thinking to myself, "just go to the experts for this". These are just my numbers, that I have. Thanks for the help.
JBL 2214H PMAX=200 RE=5.6 FS=23 XMAX=.26 LE=1.3 QTS=.24 DIA=10.2 VAS=7.9 QMS=10.5 EFF=1.1% QES=.25 |
#2 |
Here is a suggestion: b
#3 |
That looks amazing. What are the actual dimensions for the box and ports?
#4 | |
Have a look at the submitted picture and you will find a few of the dimensions needed. I didn't exactly know the driver frame width (calculated with 31 cm) or the needed depth for magnet clearance when I made the simulation. I think if you start with an internal box height of( L23 + 2 x 31 cm+ 1.8cm(Choose the baffle thickness = 2 x 1.8cm) + the internal box width = 31 cm and a L23= 223.25 cm: The total L would be slightly lower than 450 cm.( When damping material is added to the box: The effective length of the air-ways are 'virtual' longer than if physically measured.) b
#5 | |
-Stu |
#6 | |
You will find L23 to be the 'in enclosure' the inter driver section distance between the rear to the front side if you download and enter the numbers given into the free Hornresp program. b
#7 |
Driver dimensions: Full Dia. 31.11cm, Inside Dia. 29.84cm, Depth 14.60cm |
#8 |
The new hornresp program has different input par. than the one showing. What is this type of enclosure called. The internal length of the baffles? Spacing of the baffles inside the enclosure. Is there a page for the wood cuts? I can build this with just a little more help. Thanks. jayhue
#9 |
Just a few more measurements and I can start building. Length of the baffles? Dying to start this build. Please, Please, Please. thanks.
#10 | |
Sorry for being late. ![]() For the moment: Here's a revised picture with some added dimensions to study: b
| FS: JBL 2226JPL's (pair) | Frosteh | Swap Meet | 0 | 13th August 2012 01:35 AM |
| A pair JBL 2360A horns | limono | Swap Meet | 2 | 10th March 2009 11:46 PM |
| JBL 2204H- pair | winslow | Swap Meet | 2 | 21st March 2008 01:20 PM |
| Subwoofer Cabnet Extra Damping | NicolasGaal | Subwoofers | 5 | 24th January 2004 12:36 AM |
| Stereo cabnet fan? | Amigo-2k | Parts | 8 | 8th July 2002 05:38 PM |
