Old 28th September 2012, 02:37 AM   #11
That looks like enough information to start building the cabinets with. My only question at this point is with securing the front panel to the cabinet. Since the driver is internal, the front panel needs to be removable in case something goes bad with the driver. One easy way I can think of is to use button caps (screw covers) on the panel. Is there a better or more preferred way to do this?
Old 1st October 2012, 01:44 AM   #12
jayhue is offline jayhue  United States
Thanks. Starting this build. Where in the enclosure dose the stuffing go? Middle and the rear sections?
Old 1st October 2012, 07:37 AM   #13
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Stuff evenly/carefully using recommended weight of stuffing material:
Counted from the closed end to halfways down the line.
Mandatory:Insert bracings(dowels <= a foot between)) in this volume too.
If necessary:Trim the 3/4 wave dip with denser stuffing near the S1 area.
b
Old 8th October 2012, 08:33 PM   #14
bjorno: fabulous, fabulous, fabulous, Worked on the build all weekend long. I have one of my 2214's in a ported box. The other is sitting in your "monster" tapped horn enclosure design. The comparison not even close. The low side is smooth as silk. Thanks for your help.
Old 8th October 2012, 11:33 PM   #15
NWCgrad is offline NWCgrad  Cambodia
Pictures of the build? Looks like another great bjorno design.
Old 8th October 2012, 11:45 PM   #16
Old 9th October 2012, 02:40 PM   #17
BP1Fanatic's Avatar
Old 9th October 2012, 08:42 PM   #18
Old 9th October 2012, 08:56 PM   #19
Jayhue,
All the simulations in this thread are for using two drivers(labeled 2P in HR and in MJK= 2 x SD + Re/2)) in parallel and if only one driver is used the CSA's should be divided by two in order to optimal fit one driver.
I checked using one driver: Will work too if you are easy when turning the volume knob on your amp.
b
Old 10th October 2012, 02:53 AM   #20
?"simulations in this thread are for using two drivers". Does that mean that there are 2 drivers in this one enclosure? The simulation was done with 2 separate enclosures and 2 drivers. Because I am planing to build one more if necessary.
FS: JBL 2226JPL's (pair) Frosteh Swap Meet 0 13th August 2012 01:35 AM
A pair JBL 2360A horns limono Swap Meet 2 10th March 2009 11:46 PM
JBL 2204H- pair winslow Swap Meet 2 21st March 2008 01:20 PM
Subwoofer Cabnet Extra Damping NicolasGaal Subwoofers 5 24th January 2004 12:36 AM
Stereo cabnet fan? Amigo-2k Parts 8 8th July 2002 05:38 PM
Copyright ©1999-2013 diyAudio
