Box simulation in WinISD
Old 26th October 2012, 02:30 PM   #11
greg80 is offline greg80  Poland
Thank's all for responses.
I've bought in good price Dali Concept SUB (12" about 50L closed box) (price was less than I've calculated for DiY SUB). I'm quite happy with it's performance, so I've postponed my DiY SUB project for now.
But I've one question: what is your opinion about DiY sub I've described before (Dayton or Peerless driver, closed box volume approx 35 - 50L) - would it better perform than Dali? If yes that in which aspect - low frequency response, accuracy, distortions?
Old 26th October 2012, 04:01 PM   #12
Shadydave is offline Shadydave  United States
IMO, to get good SQ and reasonable SPL (for light listening, not used in anger) a sealed enclosure will need equalization.
At the very least a high order, high pass to protect the driver and a Linkwitz-Riley filter to increase low frequency response.
A TQWT, Tapped Horn or a ported quarter wave tube with an offset driver OD_ML_TL (offset driver_mass loaded_tuned length) will give fairly high SPL's with fairly high SQ and at much lower amplifier power.
OD_ML_TL's can have a very small foot print but go from floor to close to the ceiling.
This type of design is easy to blend into normal decor.
The increased efficiency is one of the big reasons that any horn will have lower distortion (when not used in anger)than a simple sealed enclosure which requires equalization and the higher operating power levels that are required to operate at Subwoofer frequencies.
That is, to operate at frequencies of which the sealed box does not want to operate.
Also, Xmax becomes a real issue as you try to lower sealed enclosure frequency response.
All that said, if you are not looking for 20 Hz content a sealed enclosure has much smaller delay issues than a ported box.
It is all a matter of preference.
Dave
Last edited by Shadydave; 26th October 2012 at 04:02 PM. Reason: I before E except in Meigs County
Box simulation in WinISDHide this!Advertise here!
Amplifier XO simulation in WinISD Iwont Tell Analog Line Level 0 21st July 2011 03:54 PM
Excursion simulation in WinISD Huricaine Software Tools 1 27th May 2011 03:41 AM
What type of box is this ( winISD ) mattpj Multi-Way 2 23rd November 2009 09:10 PM
Box volume on WinISD/BCAE seems way too small BMW M5 Car Audio 5 21st September 2005 06:15 AM
Check out this bandpass box screenshot from WinISD Pro. How does it look? treedog Subwoofers 7 23rd January 2005 09:21 PM
