Any sub plate amps with active filter for the sats? - diyAudio
Old 11th September 2012, 11:45 AM   #1
Bill poster's Avatar
Default Any sub plate amps with active filter for the sats?
Looking at 2.1 plate amps and wd like to make a sub but including an active filter for the sats (not just the sub). Is there something for sale, such as a plate amp with this feature?
Old 11th September 2012, 12:04 PM   #2
tvrgeek is offline tvrgeek  United States
Never found one. Most AVR's have "big or "small" in their config, so for the 99% of the market, they see no need. Short answer, build your own.
I don't use plate amps in my main system. I use a traditional stereo amp. It should not matter much, but the Parasound sounded WAY better than the BASH or Hafler plates I had. So, traditional active crossover and traditional amp for me. Two of my small systems still use the BASH. Integration is not as good and distortion is higher. Practicality wins though.
Old 11th September 2012, 12:04 PM   #3
Hypex makes one, and I also think that Sinewave on Aliexpress have one.
Aliexpress.com : Buy 300W Bi AMP Hi End TAS5630 CLASS D ACTIVE SPEAKER AMPLIFIER MODULE WITH SMART EQ AND WIDE RANGE SMPS AND MP3 HOST PLAYER from Reliable 300W Hi End Bi-amp Active Speaker Module suppliers on Amplifier store
Old 11th September 2012, 12:42 PM   #4
Cheers for this, I'm looking at Hypex but can't see it, which model is it?
Old 11th September 2012, 12:49 PM   #5
Fasen is offline Fasen  Denmark
Fasen's Avatar
Hypex HS200 had this feature. No longer availible.
Old 11th September 2012, 01:12 PM   #6
what about the baby Hypex AS2.100? I've sent an email to Hypex to ask if it includes a high pass filter (as I'm a noob and can't understand the info on the site exactly).
Old 11th September 2012, 01:32 PM   #7
Hypex AS2.100 will do almost anything. It's DSP powered with functions like the MiniDSP.
http://www.hypex.nl/docs/AS2100_manual.pdf
Old 11th September 2012, 01:39 PM   #8
This company seem to be the answer to my prayers; wanted to go active for a design combining subs with full range units; using passive crossovers just made no sense, complicated and expensive. Having everything in one unit (or 2) is just great, so simple, cost effective and also maximizing the performance of small full range drivers.
Old 11th September 2012, 05:04 PM   #9
Fasen's Avatar
ahhh yes forgot the AS2.100
Old 11th September 2012, 08:24 PM   #10
also more simple from mivoc
Mivoc MPA A 3120 2.1 amplifier module at 147€
Fitting a subsonic filter to a plate amp otto88 Subwoofers 42 30th September 2008 12:00 AM
240 watt, 24-db filter plate amps audiokinesis Swap Meet 3 11th September 2008 06:24 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
New PC sats...ideas pls michael Multi-Way 19 26th May 2004 12:26 AM
Active XO in plate amps amt Solid State 3 5th September 2003 09:29 AM
Copyright 1999-2017 diyAudio
