Trying to design the world's simplest sub
Old 17th September 2012, 03:12 PM   #41
DrNick is offline DrNick  United Kingdom
Originally Posted by turbodawg View Post
I am not so sure this is a good idea. I have read that the HF subs are prone to "oil-can", or pinging when used in a smaller box:
Dayton Titanic vs. Reference HF vs. HO Subs
Low end EQ in a sealed box puts lots of stress on the driver, you may have a problem here. I would suggest either:
-increasing box size, use plenty of fiberglass internally, then EQ.
-increasing box size and porting
-use a HO series woofer instaid, with the thicker cone.
......or you might be just fine.
That's a bugger, thanks for pointing that out. Would an aperiodic vent degrade sound quality? I could go a bit bigger but 100 litres (3.5 cu ft) would be seriously big.
Old 17th September 2012, 03:39 PM   #42
turbodawg is offline turbodawg
I would keep it the same footprint and build it taller. Or swap out the woofer to an HO, if it's not too late.
Don't know much about aperiodic vents, but I would think the negative effect is minor, considering how much bass you'll be generating.
Old 17th September 2012, 08:26 PM   #43
I can do internal dimensions of 45 cm wide, 60 high and 37 deep, for 99.9 litres. I'm planning on 25 mm thick ply so the external dimensions will be +5 cm in each dimension. I will now begin research on subwoofer cloaking devices. This gives Qtc of 0.812 and Fsc of 36.05 Hz before equalisation, so we're fairly low. I've ordered the HF version, so I'd rather do this justice than swap for the HO.
I've read a bit about various different filling materials adding to the apparent size, and further decreasing the Q value of the box, but would the stuffing do any good to prevent oil-canning?
Old 17th September 2012, 09:15 PM   #44
I would build with 18mm ply, 1x1/2" slat/stud bracing glued on end spaced every 6" (think of a stud wall), and line with real sound damping fiberglass, owens corning 703 2" thick or more against the slats (not the wall, with an air gap). Internally coat the walls with rubbery roofing mastic if you feel like it. That should max actual internal volume, while the fiberglass is the best you can do for stuffing.
Old 17th September 2012, 09:41 PM   #45
Sounds good, thanks! I was looking at bitumen materials to damp any overtones. I actually had a new stud wall put up in front of the brick dividing wall between my house and next door for soundproofing a few years back, and it was similar construction.
I'm so looking forward to this build. I want to get the amp and look at it to work out how to fit it in to the casing with the fins out next. Just got the confirmation the driver has shipped.
Old 18th September 2012, 12:32 AM   #46
Sounds like a good build indeed, I'm looking at doing a compact 15" HO build myself.
The tip on "floating" the fiberglass comes from recent discussions on internal sound damping. The fiberglass is much more effective than polyfill. Having it away from the wall seems to be advised.
The slat/stud bracing is my tip. Many people put huge braces across the entire enclosure, but I personally don't see how that is very efficient. A simple stud across the panel adds substantial stiffness with minimal use of volume. I'm also a fan of using the stiff plywood with a rubber damping.
It might be obvious, but make sure the box is air tight, use good glue and seal the seams well.
Old 19th September 2012, 05:05 PM   #47
Wow, the driver has arrived. That was quick.I got it from Europe Audio in The Netherlands and it's here in three days, packed in three decent boxes one inside the other, so I'll order from them again. I'm off to Paris next week, so no more ordering bits until I know how much I have left at the end of the month!
One thing I was researching was whether the miniDSP would work down below 20 Hz as all the screen shots show this as the lowest level on the basic equalisation screen. There is a post on the miniDSP site about the advanced biquad filters that confirms that the board rolls off at 5 Hz, and so with the right biquad filters I should be okay.
Old 19th September 2012, 11:58 PM   #48
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Yes, I believe when it was first released the lowest frequencies you could enter to the filters were 20Hz, which somewhat annoyed me, but I bough it nonetheless. But when I wound up trying it out myself, new software was out and you could chose lower frequencies, not sure how low, but surely low enough, can't imagine you'd ever need anything below 10Hz.
Regards, James
Old 30th September 2012, 06:49 PM   #49
Smile Design pictures
Right, I've ordered the miniDSP, but I went for the one in the box, as I've been looking at how to mount it and decided that as it is so small, it can go outside, on the back of the speaker. I was going to put it inside and run the USB extension to the back of the box, but I was wondering if a metal box would be good for shielding purposes, so I thought, may as well buy the one that fits.
I've ordered the BK MF 300 amp in the end, so now that I know roughly what the size of the bits is, here are some pictures of the design. First up, the front with all the sides on. It is 68 cm high, 50 wide and 45 deep, in 18 mm plywood. The driver is not strictly accurate, except for the outer diameter, I just wanted to see how to lay it all out.
Next a shot with the side off showing the volume around the amp as a solid, although the amp does not fill this volume by any means. This is the volume you could box out and just slide the amp in.
A view from the back with the miniDSP in green, and fins of the amp shown. I've just estimated these at 5 cm but again, this is just guessing.
I tried a few 3D modelling packages to make this, the free Google sketchup to start with, which had no CSG at all, then the Autodesk 123D Beta. Both if these seem determined to insulate the user from the coordinates of the things on screen. I sort of got somewhere with the Autodesk 123D Beta, the free version, but I just want to type in dimensions and rotations, and then see if it has worked out how I planned. I don't really like having to select anchor points off the screen. I never knew quite what context I was working in, and trying to find how to cut a hole in a plate was a bit of a drag. The tutorials look amazing, but it also crashed quite a few times, so I gave up and used COMSOL to draw the plans up. I have this for work, and it is a full Finite Element modelling suite, and I have seen people doing acoustic models with it. I have no experience of that yet, so this is just for the pictures. I have not added bracing yet, but there will be some. I might just see if I can use the acoustic model to work out the best arrangment.
With regard to the amp, I have mounted it vertically to let the fins work efficiently, and I'm just trying to decide if I'll just create an open box facing outwards (but sealed off from the main volume) of the correct dimensions right against the left side at the back so it can slide in, and I can have some allen key headed bolts projecting through the side (countersunk in flush so they don't stick out) to secure it once in place, or even make the side above it open out for easy access The alternative is to mount the amp as a plate amp, creating a seal around the heatsink. It does not look like it is designed for this though, so this may not be easy, or effective. I also worry about microphony of the components, and even shortening their lifetime by fatigue inside the box. The final option would be to build it into a separate metal or wood case and sit it on top, or on the back but that does not seem very elegant, and the cost of the case might be quite high for something 33 cm by 10 by 10 or so.
Not shown but also ordered are a 7812 Regulator, and the two recommended caps to go with it for smoothing, a little bit of circuit board to put them on to and some hole supports to mount them, and phono socket to fit on the back of the box to take the signal through to the amp. I'll be taking the power for the miniDSP from the amp, regulating it and feeding through, as jwmbro suggested. I cannot seem to find details of what the plug on the miniDSP is, or is it just a terminal block that could just accept tinned wires? I might have to get a new shielded audio cable to connect the lfe output on my amp to the miniDSP. Any recommendations gratefully considered. I have also ordered the volume control pot with the DSP so my wife can turn the sub down without connecting a USB cable to it, so that will be mounted on the back too.
Anyway, the final details from the construction point of view will be to round over the edges with a (borrowed) router to about a 12 or 15 mm radius and then paint the case to match my floor, in gloss French grey. I was wondering about making another recess in the back big enough to sit the miniDSP in, but as the fins for the amp have to stick out a bit to get decent cooling, it hardly seems worth it.
So, just waiting for the other parts, but may be next weekend I'll get the wood and start cutting. I have a final question about using non-magnetic bolts for fixing the speaker driveror the amp to the box. Is it necessary?
Old 1st October 2012, 05:37 PM   #50
weltersys is offline weltersys  United States
weltersys's Avatar
No. With an aluminum frame driver, there would be no difference whatsoever using non-magnetic bolts, and with a stamped steel frame steel bolts simply extend any magnetic leakage from the basket.
Trying to design the world's simplest subHide this!Advertise here!
World's smallest subwoofer? ByronInPortland Subwoofers 12 16th November 2011 04:01 AM
World's most expensive paint. scott wurcer The Lounge 19 12th January 2010 04:16 PM
World's Largest Subwoofer orangeshasta Everything Else 9 27th July 2008 03:06 PM
The world's sexiest finish? The Dudster Multi-Way 8 8th November 2004 12:41 PM
World's Ultimate Subwoofer? dantwomey Subwoofers 10 21st April 2004 12:21 PM
