bresc Audio fundament 1.1 - Power amp Schematic wanted
I have on my desk a damaged device cause a burned voice coil. The driver model is the "M22WR-09-08" from D.S.T. (Tymphany), formerly Vifa.
Datasheets are here:
http://www.diyaudio.com/forums/multi-way/107629-looking-m22wr-09-08-datasheet.html#post3157683
In case of a closed box this would be an easy task. But this device is a band pass and thus the effects by change of the thiele small parameter brings other sound effects as usual at closed boxes.
Therefore the question: which driver from currently production (or at least currently available) is suited?
Thanks for advices.
