Building a ported subwoofer with tight bass ... how?? - diyAudio
Old 25th August 2012, 03:55 AM   #1
dannyjmf's Avatar
Default Building a ported subwoofer with tight bass ... how??
hi ...
need help here ... i am interested of ported subwoofer boxes all the time (in fact have build 2 of them) due to their good efficiency (higher output at lower frequencies)...
but so far i am pleased with the output level they produced (very power bass) ... but there is something is missing ... that is good transient response(tight bass for eurodance, techno).
i wonder if for a subwoofer box a larger box then the suggested volume or smaller will give better transient response. Or i can use equalizer to improve the transient response of a ported subwoofer.
In fact, i do have a pair of sealed sattelite speakers which produce nice tight bass although the bass is not heavy.
pls help ... opinions and suggestions are very much welcomed
Old 25th August 2012, 04:42 AM   #2
kctess5 is offline kctess5  United States
If your not fixed on bass reflex then there are many other subwoofer options which in general are considered to have more "tight" bass.
Sealed would be the "audiophile" choice, but requires a lot of power and large drivers.
If it's the efficiency you're after than some kind of horn could suit you well. There are many tapped horn designs out there that are quite good, and can be MUCH more efficient than bass reflex. I have built a few negatively tapered horns and been quite happy. I actually have not built a bass reflex sub yet, because all the ones I have heard I felt were too "mushy," so I prefer some kind of horn.
I know this doesn't exactly answer your question but I hope it helps
P.S. "Or i can use equalizer to improve the transient response of a ported subwoofer" I highly doubt there's much you can do with an equalizer for transient response. It could be used to decrease linear distortion (frequency response) but that's about it.
Old 25th August 2012, 05:29 AM   #3
OscarS is offline OscarS  United States
the fact that you like the "tight bass" from your satellite speakers sorta tells me that you're after more pronounced midbass. How high in frequency are you crossing over your current subwoofers?
Old 25th August 2012, 05:50 AM   #4
Patrick Bateman's Avatar
Everything else being equal, a tapped horn is no more efficient than a vented box IF box size is equal. There's no escape from Hoffmans Iron Law.
Old 25th August 2012, 09:18 AM   #5
MaVo is offline MaVo  Germany
tight sound comes mostly from the frequency response. for this really dry sound you want a woofer that does not play much lower than 50hz and has a slightly rising response, so it is louder at 150hz than at 50hz. also, it may not have huge irregularities like bumps in its response. this is easily done with closed boxes since thats about their natural response. with reflex, you need to be attentive that the low end isnt bumped up, making the sound boomy.
you might also try to experiment with proper bass traps and/or nearfield placement of the speakers for the better direct/ambient soundfield ratio.
Old 25th August 2012, 09:58 AM   #6
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Up for a little challenge then? The measurements look legit on that one...
Dan
Old 25th August 2012, 10:38 AM   #7
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Approximately over 100dB from about 50Hz up using 2.83V into a nominal 8 Ohm load? Box size I estimate to be about 100l net, here's a BR that does about the same thing.
Note that the statement was same efficiency per box size, not per price, as this does have 800€ worth of Italian neo drivers in it (though you might be able to do it cheaper, this was with the second driver I tried for which I already had hornresp inputs, didn't bother optimizing the price.
Regards, James
Old 25th August 2012, 10:42 AM   #8
diyAudio Member RIP
There is a whole range of ported box bass alignments that differ
considerably in the subjective "tightness" of reproduced bass.
Often vented is chosen to optimise f-3dB. Depending on the
driver and box optimising f-6dB to f-10dB can produce
deeper and tighter bass that is subjectively dryer.
Rounding the knee of a vented response improves transient
response. Can be done by port detuning only, or sometimes
a combination of a smaller box and less detuning is useful.
rgds, sreten.
Old 25th August 2012, 10:44 AM   #9
NEO Dan's Avatar
@ jwmbro
You must have missed his foot in mouth moment...
So that's great, but can you do it with a single 12"?
Dan
Old 25th August 2012, 10:46 AM   #10
diyAudio Member RIP
Port only - much tighter and much deeper, good with room gain :
The Missing element in Chipamps> how to achieve tight kick drum bass with chipamp? rhythmdiy Chip Amps 37 25th November 2013 06:15 PM
how to get tight bass with little overhang loheswaran Multi-Way 7 11th May 2011 02:00 AM
Building a Bass SS amp out of a old car subwoofer...need advice! Audiological Solid State 11 5th June 2010 10:54 PM
Best tubeamp for metal, tight bass alspe Tubes / Valves 7 19th October 2009 11:29 PM
why bass is tight and controlled on SS than chipamps like lm3886? rhythmdiy Solid State 46 14th December 2008 01:32 PM
Copyright ©1999-2017 diyAudio
