SS15 or Tham 15? - Page 4 - diyAudio
Old 12th October 2012, 08:03 PM   #31
djk is offline djk
djk's Avatar
Alas, I didn't think to save it, and Danley has since changed his site.
IIRC, the minima was at 28hz.
Candidates for the Darwin Award should not read this author.
Old 13th October 2012, 11:07 PM   #32
weltersys's Avatar
IIRC, Tom Danley told me the TH-118 was basically identical inside to the TH-115, though the impedance minima for the TH-115 is listed at 78 Hz, and 67 for the TH-118 .
Art
Old 13th October 2012, 11:19 PM   #33
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I give you the fake'n bake deluxe royal with cheeze:
Dan
Old 14th October 2012, 08:04 AM   #34
djk is offline djk
djk's Avatar
" though the impedance minima for the TH-115 is listed at 78 Hz, and 67 for the TH-118 ."
I was referring to the 1/4W impedance minima, which looks close to 28hz in the graph on post #33 (thanks to NEO Dan for the graph!).
On the older TH-115 sheet that I have, this minima is at about 36hz, hence the conclusion they are not the same length.
Old 15th October 2012, 01:02 PM   #35
Djim is offline Djim  Netherlands
Old 15th October 2012, 01:38 PM   #36
th118 has a constriction in the path at the last bend.
Why?
What does that achieve?
Is it modeled in a sim?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th October 2012, 01:39 PM   #37
From ProSoundWeb
The TH-118 kind of fell into my lap,” laughed inventor Tom Danley. “Eighteen Sound introduced a new 18-inch driver that is tremendously powerful. I looked at the computer model of the TH-115, which is, of course, well suited to a 15-inch driver.
“Remarkably, when you drop the new parameters in, the model calls for essentially the same box that we are already using for the TH-115. We prototyped one with the 18-inch driver, and the sound was simply amazing.”
Old 15th October 2012, 01:41 PM   #38
Why? What does that achieve? Is it modeled in a sim?
Hi Andrew,
It is no more than a practical solution in order to make an 18" fit. The restriction is less than 1/6th of the path (and probably follows the round curve of the driver's edge) so its influence is very minimal.
Old 15th October 2012, 08:13 PM   #39
djk is offline djk
djk's Avatar
I guess the question still remains, why do they graph so different in impedance then?
Old 16th October 2012, 09:59 PM   #40
weltersys's Avatar
The graphs use different smoothing, which accounts for some difficulty in comparison.
Using Hornresp, the Keystone simulation impedance maxima for a B&C 18SW115-4 is about 3 Hz lower than for an Eminence 4015LF, less of a difference than the TH-118 /TH-115, but a difference.
For what it's worth, the simulation reflects the actual FR measurement, though I never have tested impedance.
SS15 build x8 bko69 Subwoofers 79 9th June 2016 01:39 PM
Air leak in ss15 TH severely affect output? m R g S r Subwoofers 23 8th March 2015 08:10 PM
Scaling up the SS15 for an 18" driver and other compact 18" designs col Subwoofers 32 23rd January 2012 10:17 PM
Is LM3875 better tham LM3876 goldyrathore Solid State 12 12th July 2005 08:53 PM
For Sale: One TC Sounds HE-15 cube (similar to Stryke Power 15) Phloodpants Swap Meet 1 7th May 2001 10:44 PM
Copyright ©1999-2017 diyAudio
