High resonant frequency sub
Old 21st August 2012, 02:42 AM   #11
diyAudio Member RIP
6 x 8" drivers in each 20L box will need shedloads of power to drive
them to there excursion limits in the bass*, and at 3.33L per driver
your living in cuckooland regarding any suitable drivers for the job.
You need to do some proper modelling.
rgds, sreten.
* Well beyond their thermal limits I suspect, but
I'm too lazy to do the actual modeling for you.
Old 21st August 2012, 01:41 PM   #12
turbodawg is offline turbodawg
Originally Posted by AJ34 View Post
Are there any commercial designs based on this principle?
This velodyne is a small one, and there are definitely others across a range of sizes.
MiniVee 8 Inch Subwoofer
Old 21st August 2012, 01:54 PM   #13
I picked out some cheap woofers for you:
Aura NS6-255-8A 6" Paper Cone Neodymium Magnet Woofer 299-030
Here's a sim of one woofer in 15L....
Another Jambox on the Horizon?
So I think you're asking alot, but feel free to model it yourself and see if it will work or not. Maybe 4 woofers in 30L per side?
Old 21st August 2012, 05:11 PM   #14
diyAudio Member RIP
Hi, attached is 1, 2, 4, 6 and 8 NS6's into 20L sealed, rgds, sreten.
Old 21st August 2012, 10:41 PM   #15
diyAudio Member RIP
Hi, same thing with 30L instead of 20L, rgds, sreten.
The above also shows 40L by transposing, blue = 2 drivers.
FWIW searching indicates a better choice than the NS6 is
a shedload more expensive. The nature of the NS6 motor
indicates progressive lower harmonic distortion as levels
increase but no real critical excursion point where higher
harmonics suddenly appear, see Home .
Old 21st August 2012, 11:34 PM   #16
AJ34 is offline AJ34  United Kingdom
Thanks again for your input folks - your assistance is very much appreciated.
As regards subwoofer design, I feel I'm currently at the "brainstorming" stage. All possibilities are still under consideration although I am driven by domestic compromises rather than potential sound quality - shame but I guess that's life! This means that my design options appear very limited.
Two, small (approx. 20ltr) subs that double as stands for my active monitor speakers would be the domestic ideal but it seems unrealistic to load each sub box with six, cheap 6" drivers, let alone 8" ones! - thanks for the plots, sreten. As mention before, the sub's size is determined by them needing to double as stands therefore I have little flexibility regarding size. For me, it looks like two, 20ltr box subs are the way to go so I'll look into more suitable driver line-ups. One final thought...
What about this unusual (to me, anyway) Celestion open baffle, series dipole(?) design from the 1980's - pictured near the end of the article...
Designing Loudspeakers - Part 15 Open Baffles and Bass
Two, 12" units are used in open baffle but with one driver positioned behind the other and both cones move in the same absolute direction. I guess adding the back driver has the same acoustic effect on the front driver as curving the front baffle around the sides but without reflection problems? Maybe I could use two banks of three, 8" drivers (probably not cheepies - possibly PA types) instead of the two 12" drivers Celestion use? Also, the drive units will need to face the listening position, more or less, so I can't position them at the sides.
Old 22nd August 2012, 12:02 AM   #17
diyAudio Member RIP
In the UK your driver choices are limited. What are the speakers you
want to add a sub/stands to ? You can angle the back backwards
to give you more box volume to work with if its needed.
The SL600 open baffle sub is a strange beast for a box speaker,
good information is hard to find and your completely on your
own with a triple arrangement, not something I'd recommend.
KISS should be your principle, related to your main speakers.
rgds, sreten.
Old 22nd August 2012, 11:15 PM   #18
http://www.studiospares.com/studio-monitors/studiospares-seiwin-powered-monitors-pair/invt/248030/#ReviewHeader
I suppose so, I guess every litre helps. Percentage wise, I could probably gain an extra 20-25% volume.
Indeed it is. Each Celestion sub occupies a really small space considering that two 12 drivers are used thats what attracted my attention. Having trawled the internet looking for info, a few points come to light: they seem to be heavily EQd (as one might expect), they are prone to bottom out at the very low end, they dont manage high SPLs due to the design, they need to face forward and their sound quality is fantastic, evidently.
Found some QTX drivers. The 902.208 in particular seems good value. TS parameters are given.
http://avslgroup.com/en/product/902.208UK
Its been discontinued but some outlets are still advertising them for between 10 and 15 each hopefully, they still have stock. Ill have a play with the Linkwitz Lab closed-box spreadsheet and try out some possibilities.
High resonant frequency subHide this!Advertise here!
resonant frequency bdgf2004 Car Audio 10 30th August 2011 02:48 AM
speakers operating near their resonant frequency kanguru007 Multi-Way 26 28th March 2009 02:02 PM
Tweeter resonant frequency missing Dave Bullet Multi-Way 20 13th June 2007 10:02 AM
What about resonant frequency? Javachip Full Range 6 15th June 2006 06:12 AM
Resonant Frequency of an enclosure AudioFreak Multi-Way 9 4th July 2003 12:30 AM
Copyright ©1999-2017 diyAudio
