Old 19th August 2012, 10:45 AM   #11
Frode is offline Frode  Norway
Originally Posted by TundraLTD View Post
If you can find a MTX T9515-04 over there just do what I did. NewToy link, I'm ending up with 4 of them. Drivers coming from all over the country
I really like your design, but it seems to be hard to source the drivers.
Frode
Old 19th August 2012, 01:56 PM   #12
TundraLTD's Avatar
Frode
The drivers have been discontinued, I'm assuming that's why the TH-50 was as well. The Orion HCCA152 will work in the design with slight modification, but it cost a bit more
Old 21st August 2012, 10:04 AM   #13
djk is offline djk
djk's Avatar
You might look at building a pair of sealed PPSL with 12s and a Linkwitz transform to get the 20hz. A cabinet with the same footprint as the SH-50 and adjust the height as needed for net volume (I'm guessing 18"~24" would give the best height for imaging from the SH-50).
This would give minimum group delay and a pair stacked MTM style would give a stable pattern through the crossover region, and delay might not even be needed.
Candidates for the Darwin Award should not read this author.
Old 21st August 2012, 10:10 AM   #14
Any suggestion for drivers?
Frode
Old 21st August 2012, 07:40 PM   #15
Rojoh is offline Rojoh  Norway
Rojoh's Avatar
I would choose the Dayton RSS-315HF (8 ohm version). Probably similar to those used by Ocean Way in some of their monitors.
25 Eliminator Daytona, 30 daytona, E-ticket - YouTube
You could also mount the drivers (PushPull) like Tannoy does in their VQ-range:
Putting out fire with gasoline.
Old 21st August 2012, 07:50 PM   #16
Rojoh,
Push pull means having one driver magnet out, both the woofers in the picture you attached are cone out.
"V" loading as in the picture does allow the use of a pair of larger drivers in a smaller frontal area, two 15" or 18" could be mounted in a "V" with the same frontal area as an SH-50.
Art
Old 21st August 2012, 08:09 PM   #17
Rojoh's Avatar
Originally Posted by weltersys View Post
Rojoh,
Art
Yes, You're right. I ment (but didn't explain it well ) that he could copy the the box shape, but flip one of the drivers.
I also always forget about SH-50s size. On pictures they often look so compact. One option could be something like swedish Procella does:
Old 23rd August 2012, 09:37 AM   #18
djk is offline djk
djk's Avatar
"Any suggestion for drivers?"
Given you modest output requirements, and given that there will be four drivers, any half-way reasonable driver should do (really). Push-pull really reduces the distortion so that an inexpensive driver can sound quite good.
I was looking at some TC Sounds Epic 12s for a friend, they have around 22mm of x-max and are about $200 each. I don't think you need anything quite that extreme.
Old 30th December 2012, 07:19 PM   #19
Q14 is offline Q14
DJK
give Windyridge a shout, lost your email.
GB
Power amp for Danley TH-221 subwoofer ashok Subwoofers 5 20th August 2012 02:41 AM
Now THIS is a subwoofer. 5 - 50 Hz. overtheairbroadcast Subwoofers 10 9th March 2012 06:47 PM
50 hz booster circuit for subwoofer jaya000 Solid State 4 27th March 2008 03:43 AM
sunfire, infinity + other subwoofer plate amps for sale $50.00 NickB Swap Meet 3 28th February 2005 11:39 PM
Subwoofer for 50-60L enclosure...... help! Mutley666 Subwoofers 3 13th January 2005 05:53 PM
Copyright ©1999-2013 diyAudio
