I just stumbled across this NEW 150w 15" WOOFERS COMPOSITE TREATED CONES -CLEARANCE | eBay and I'm curious to see what others think; is it a good deal?
Rated Input Power: 100W RMS Max Input Power: 150W Impedance : 8 Ohms Frequency Resp: 28Hz-1.5kHz Resonant Frequency: 28Hz Sensitivity 1W @ 1m: 94dB Voice Coil Diameter: 49.5mm QMS: 4.29 QES: 0.44 QTS: 0.4 VAS: 314.6L Nett Weight: 5kg Magnet Weight: 1.4kg Cutout Diameter: 355mm Mounting Depth: 160mm Suggested Vented Enclosure (Tuned to 45Hz) Volume: 100L Port: 2x 100mmų x 100mmL Suggested Sealed Enclosure Volume: 80L |
#2 |
Dilletante, tinkerer and beggathoner supreme
Not at $99-
I reckon $55- would be a decent price, I have the 12inch from the last sale (Avico branded) it is the X-Max that limits their performance. But model them and see what you think, I did ask if there was a discount for buying multiples but I was told NO
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 |
I should probably finish all the other projects i have going on anyway...
#4 |
I resemble that remark
| EOS 12V 100W SMPS Ebay UK bargain | sharpi31 | Parts | 0 | 22nd September 2010 04:45 PM |
| Possible Ebay bargain | Shoog | Tubes / Valves | 8 | 23rd September 2009 12:14 AM |
| EBAY 'scope bargain | DRC | Equipment & Tools | 0 | 27th August 2008 08:19 PM |
| Potential Bargain on Ebay | ShinOBIWAN | Multi-Way | 15 | 22nd May 2006 08:47 PM |
| Bargain turntable on eBay | RADIOLEE | Analogue Source | 4 | 10th August 2002 05:58 AM |
