Compact Dayton Titanic 15" Offset Horn Design
Old 30th July 2012, 02:21 AM   #1
vnwhite is offline vnwhite
Default Compact Dayton Titanic 15" Offset Horn Design
I've been playing with Hornresp modeling compact offset bass horns for HT use. Design parameters are a sub that goes to about 120dB from 20-150hz in as compact a space as possible - I have a 22" max width restriction. I'm planning on building two subs to be placed in the front room corners and external proamps plus MiniDSP equalization would be utilized.
After modeling several different 15" drivers, the Dayton 15" Titanic seems to produce the most dBs and the smoothest frequency response for very small enclosures. Attached is a Hornresp design I ended up with and a preliminary layout, which ended up being about 2.5'x2.5'x2'. I've designed and built several different types of speakers before, however, I've never built a bass horn. Do any of you experienced horn builders have any feedback or comments about the design?
Thanks,
Vince
File Type: txt compact.txt (421 Bytes, 9 views)
Old 30th July 2012, 11:25 AM   #2
Default Additional design images
Here are the images of the Hornresp parameters and SPL frequency response chart.
Compact Dayton Titanic 15" Offset Horn DesignHide this!Advertise here!
Dayton Titanic MkIII 15" sub bottom out chainenoble Subwoofers 18 13th December 2010 04:59 PM
Dayton Titanic MkIII 15" woofer -- problems chainenoble Subwoofers 4 22nd April 2006 02:39 AM
Dual 15" Dayton Titanic MKIII Design Help chance_11 Subwoofers 25 3rd February 2006 07:46 AM
My first DIY project. The 15" Dayton Titanic MKIII. Pics perpetual Subwoofers 11 18th April 2005 03:56 AM
Enclosure for 15" Dayton Titanic ihearyou Multi-Way 3 19th December 2003 12:12 PM
