Lab 12 Based Offset Driver - Mass Loaded - Transmission Line (OD-ML-TL) Design by Bj
Old 15th January 2013, 02:05 PM   #81
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Nice build! It still looks like a regular BR enclosure from the outside.
Old 10th March 2013, 10:57 PM   #82
vnwhite is offline vnwhite
Default Why the T-TQWP vs Vented
I found this thread several months ago and was really intrigued by the design. So, I started modeling with other drivers and simplifying the design until basicly I ended up with a vented enclosure with a slot vent. Now, I'm really puzzled. Can someone explain why someone would want to go to the added complexity of a folded T-TQWP design versus a vented design, when Hornresp pretty much shows the same response in the same enclosure volume.
To show what I mean, I took Shadydave's current build and massaged it into a vented design that pretty much has the same SPL response and enclosure volume. What am I missing here?
-Vince
Old 12th March 2013, 10:06 PM   #83
Shadydave is offline Shadydave  United States
vnwhite,
The correct way to model a port loaded (BR) box is as shown below.(following your drawing)
As to your question, I am not sure.
They both seem to model quite similarly.
Also, the first box that I built was not really built following the plans and should probably not be used as an example.
That said, I ran the Original "final" HRSP model and the results are quite similar.
The BR box does have a phase issue right at the electrical impedance peak @ 36 Hz.
And, in my experience BR boxes are often quite "boomy" or show "single note boom".
The only thing that I can say, is the one that I built (incorrectly) sounds very good.
I have since built another following the original "final" plan, and am just waiting for some stuffing material so I can glue the last side onto the box.(and wire, sand, install feet, quarter round and paint it).
I plan on performing numerous back to back tests to see how much I screwed up my simplified version of the OD_ML_TL box.
I look forward to any comments by those who know more.
Dave
Old 3rd April 2013, 11:59 AM   #84
_henry_ is offline _henry_  Australia
hi shady,
looking forward to your impression on the simple and original plan
i got 2 lab12 to build and i think this is the best in terms of size and projected response.
cheers
henry
Old 3rd April 2013, 02:04 PM   #85
Default Update
I have built 2 versions of this subwoofer.
I was confused by the Sketchup drawing of the box, specifically the 12.4” dimension.
The 12.4” dimension should probably read 12.908” as that is the effective length of the top of the port, but the original drawing has a flat on the port's rear top angled board to make up this difference.
This confusion ultimately caused me to build the first version with a shorter slot port.
I did not make the change without simulating it in Hornresponse and found that, at least in simulation, there seemed to be many small changes that would not make a difference.
I also added too much stuffing in the first design as I did not understand, I mean I screwed up.
There is a jog in the FR curve according to HRSP that changes drastically with small (1-2 cm) changes in port length but I am not so sure that the jog exists at all after stuffing in the line.
I just plugged the second box into my amp Monday night and plan on doing some sweeps next weekend after I break in the driver. I need to do impedance sweeps also.
I am generally very impressed with both boxes.
I have a pair of Infinity 1262’s in 73 liter sealed boxes driven to 420 Watts each that have a rising response (in room) down to 35 Hz before they start to roll off, but the Lab 2 subs add quite a bit to the mix that I would have never realized existed without them.
The Lab 2 subs can be driven to between 150 and 200 watts without their amplitude reaching more than about ˝ of Xmax.
...This is not what HRSP predicts.
I have voltage limited to between 24 and 29 V depending on my mood and how much I will tolerate things falling off of shelves.
I broke a large picture window with the 2 Infinity boxes and one Lab 12 sub, both with strong (48 dB/octave) HP filters at 20 Hz.
The first Lab 2 sub I built shows an F3 of about 16.5 Hz, but I have a concrete house, both floors and walls and the 2 Infinity 1262’s are in full concrete corners.
I drew this box using Cadkey in numerous forms, but could not get my drawing to agree in path length with the “original final” sketchup drawing.
I spent allot of time trying to get the path length measured exactly and I am pretty sure that my drawings are correct.
The 2nd version I built is essentially the same as the “original” design except that I lowered the driver 8.6 mm and left out the 2nd piece of ply at the top end of the line.
This makes the lengths slightly different and I did this because HRSP says this will get rid of the jog at 80 Hz.
My initial impression concerning the longer port variation is it does sound better, but I have not done any measurements yet.
The longer port is hard to construct and this is one reason I did not build it at first.
This may have been a mistake.
I attached a drawing of the "Original final" design, as best as I could draw it.
The dimensions of path length do not agree with the sketchup versions.
I also attached a drawing of the 2nd box I built (BTN-A), where I tried to copy as exactly as possible the "Original final" design but with path dimensions that HRSP likes.
The hard part of the port is pictured as well as the 2nd box I built.
I decided to use 22.5 degree angles to join the top of the port parts, this both made it harder and easier.
I did not mount the driver in a counterbore on either version but I cut a 17 mm deep 45 degree angle on the back of the baffle in the 2nd version.
I do not know if it will make any difference as the driver has a large open area in the basket.
For now I included a cutlist of the box that I just built, but I strongly advise anyone to draw any box that they are building, at least on the side section of plywood to get everything to fit together.
I will post more info later
Dave
I also think it is a bad idea to write a post in Word and cut-N-paste it into the forum
Old 3rd April 2013, 02:36 PM   #86
NWCgrad is offline NWCgrad  United States
Shadeydave, great to read that you lime the results of your build. I'm looking forward to seeing the measurements when you complete them. I still have my two Lab 12 drivers, but as long as I'm in Cambodia my build will have to wait.
Old 4th April 2013, 02:52 PM   #87
BP1Fanatic's Avatar
-Vince
Lab12
132L BR, 23hz tune vs 127L T-TQWT, 24hz tune, 225wrms, 13mm xmax.
Both enclosures can be built with 7 boards.
Old 22nd April 2013, 01:11 PM   #88
DrDyna is offline DrDyna  United States
DrDyna's Avatar
It turns out my basement leaks a little water...now that I have a perfect excuse due to one of my horns getting wet I'm going to build a pair of these (2nd fold version from post #85) with the Epic 12s to see what happens.
Nothing to lose, I'm going to have to toss my horn cabinets anyway, might as well try to salvage some of the wood and see what these sound like.
Edit: I realize now after writing what I wrote and seeing it next to my sig that I could have brought this on myself with whiskey and deadmau5.
Old 22nd April 2013, 04:46 PM   #89
Default Some more tests
So I took both OD_ML_TL boxes outside with a Crown xti 1002 amp and my laptop with REW an Art dual USB pre and an ECM 1000 mic.
I set up on the lawn with the microphone 1 meter from the front of the boxes and about an inch from the ground.
I was doing sweeps from 20 Hz to 300 Hz and usually doing 2 or 4 and letting them average.
All of my RTA data is unsmoothed (how do people get it to say that on top of the graph?).
The first graph shows my first simplified version box, in room. This was done last January. I also included similar outdoor sweeps of both boxes that I built on the same picture.
These were done with all of the same settings, just outdoors.
I realize that room response is a pretty big thing, but I had no idea how big it was, and how much low extension it can add.
These sweeps were all done with 512K length, 20 to 300 Hz (I did not realize this setting in REW would sweep the driver from 10 Hz to 600Hz, hence some confusion before concerning cone flapping and no acoustic output) and 2 or 4 sweeps.
The data is unsmoothed but the SPL level was calibrated a week before, so I imagine it is not all that far off but I can not guarantee it to be correct.
I have backed down to a 20 Hz, 24 dB/Octave HP filter for general listening and this does not cause any distress.
I run the limiter threshold at between 25.11 and 29.14 Volts and for the sweeps I set the attack to 10 mS and the release to 10 Seconds. (I use 10 mS and 200 mS for Music and HT)
In looking at both the phase information and a small difference in frequency response (not lower extension, but up near 80-100 Hz) there are some noticeable differences between the first, simplified version of the box that I built and the version that closely resembles the “final” version.
I ran the 2nd box at -8 dBFS and the first (simple) box at -10 dBFS settings on REW in the first picture otherwise the curves would have overlapped much more.
I was trying to do some impedance sweeps but I am getting some confusing results.
The Impedance peaks come out pretty close to what HRSP predicts, and there is a small difference between the two versions of the box.
However the difference is small with the first box (with the shorter vent) coming out at a peak of 33.65 Hz and the box that closely resembles the “final” design peaking at 34.42 Hz.
The result that confuses me the most is, if I do a “measure T/S parameters” with DATS it tells me that the Re of the driver is 12.6 ohms.
I just bought Virtins virtual instrument package and plan on testing for THD as soon as the rain stops. I would have done it Sunday morning but between the neighbors coming over (they live 1//2 a mile away) but I guess 8:00 AM on Sunday is a little early, and the rain that started a few hours later I had to call it a day.
One thing I will say to NWGrad, I am using a Crown xti 1002 because I liked the DSP option when I looked up the amps specs after you said you were going to drive your OD_ML_TL’s with one. You also said you might use a 12 dB/Octave BW HP filter.
I was testing with it set to 24 dB/Octave and 29.14 Volts limit (~ 200 W) with a starting frequency of 20 Hz, but then I did a sweep with the HP filter set to 12 dB/Octave and the amp immediately shut down with whatever protection scheme it has. This should have been less than 200 Watts rms as the measured impedance is always higher than the 4.29 ohms used in the HRSP simulation, usually quite a bit higher. I am unsure about what type of protection circuitry the amp has but it came right back on in 10 seconds or so when there was no longer an input signal.
A quick question, Does anyone ever use a Zoebel network on a sub?
I expected to see more difference between the simplified version that I built at first and the “real” design but maybe the phase information tells most of the story where the simple design has it’s 1st phase wrap at 43.5 Hz and in the 2nd box I built, this happens down lower at 32 Hz or so.
If I place both cabinets next to each other and set the limiter at 29 Volts in my concrete house these can definitely be used in anger.
All Hornresponse screens are from the input that shows the actual values for the 2nd box I built.
I expected to see a flatter response with the outdoors tests.
I am wondering if I did something wrong.
I used the USB pre directly into the amp and the amp had a 20 Hz, 24 dB/Octave filter, but no low pass filter setting at all.
Is this type of falling response normal for outdoor testing?
Dave
PS. DrDyna, the cutlist I included in my last post is for the 2nd box in post 85 and this box is almost exactly the design called "FINAL" by Bjorno and NWGrad.
The only difference is the line is 1.8 cm longer and the driver is 8 mm lower.
I did this because HRSP seemed to like it.
File Type: jpg 1st Inroom and both outside_Red -8 dBFS_blue - 10 dBFS.jpg (113.3 KB, 159 views)
File Type: jpg 2nd box_34.42 Hz impedance peak_Re- 12.47 ohms.jpg (298.8 KB, 55 views)
Last edited by Shadydave; 22nd April 2013 at 05:08 PM. Reason: A bunch of mistakes
Old 22nd April 2013, 10:18 PM   #90
shadydave,
thank you for posting these details. its very interesting the impedance behaviour heavily altered in this box. i think this was the case with the original LABhorn, as i remember the impedance on the box will be around 8ohms with the LAB12 6ohm.
in this case, you can save the 1ch from your amp by driving the 2 LAB12 with single channel with similar power and SPL, isnt it?
the room response is very flat, is that EQ'ed?
cheers
henry
Lab 12 Based Offset Driver - Mass Loaded - Transmission Line (OD-ML-TL) Design by BjHide this!Advertise here!
Chosing the taper in transmission lines, mass loaded or not Squeak Full Range 0 12th March 2011 11:02 AM
Slot loaded cube box for Lab-12 driver ashok Subwoofers 0 22nd March 2010 03:13 PM
Alpha Transmission line - can the driver be offset? adamt Multi-Way 3 26th June 2006 11:36 AM
Mass Loaded TL - Getting started? Dave Jones Multi-Way 4 12th April 2004 11:18 AM
