#51 | |
Thx for the rework tho.
System: Hitachi HT-320, HK 330a, Energy 3.1e speakers and xbox360, android phone headphone out for hirez FLAC playback. |
#52 |
This looks like a fantastic design. Awesome bandwidth for a sub, and not huge! If I was considering a sub build, this would be VERY high on the list...
#53 |
I wish I could build now, my sealed 16" boxes with the LAB-12s has in room down to 35 Hz. These will be a significant improvement. I make the attachments using Microsoft snip and paint. Steve |
#54 |
Hi NWCgrad, All
The outline of the suggested port system and the new position of the driver are IMO nearly spot on. I've tested at least 5 damping schemes and a few different layouts of corner CSA: s / sections definitions. Check out this MJK simulation I found best to represent your drawing: Look for eventual errors that are 'mistakenly' entered for the CSA: s and section lengths. I will test the impact of a suitable HPF and post the result later. b
#55 | |
There's a 70's Cadillac in the driveway and I bet one of these would fit perfectly in the back of it! |
#56 | |
I think Bjorno did a fantastic job on the design, and the fact that the TC Sounds driver models as well or better than the Lab 12 is a cool bonus. I plan to build two this summer, probably with grade A plywood from a specialty wood store insteaad of home depot, amazingly the cost isn't as different as one would think. Two subs for two sheets of plywood seems pretty good. |
#57 | |
I am still going over your attachment, you sure can pack a lot of information into a single post. |
#58 | |
I looked at the sections in the transmission line profile in your attachement. It looks like the version in the spreadsheet has a total length 7.91 inches longer that the drawing. I believe it is due to the additional volume showed in the profile due to each of the folds of the enclosure. Thus, I "think" there are no errors entered for the CSA's. All the secion lengths look correct to me, I lined up each length on the model and the drawing to compare and they seem to match pretty well. Am I correct? |
#59 | |
How does this sub compare to Don's fold of a TH using LAB12 and a series inductor, which is ofcourse capable of 130db? Admit that it is much bigger, but that apart, in terms of sound quality for music and impact for HT?
Sam |
#60 | |
I will build two of the Lab12's in a few months and see if I am satisfied. My current setup in Cambodia (two year assignment) only goes down to 30 Hz. The current setup is two Lab 12's in sealed 16" cubes and an old Paradigm PDR 12. With them being flat to 20 Hz, the Mal-X may be more trouble than it is worth to integrate. I cannot say how important the range from 12 to 20 Hz is for movies, I do not think it at all important for music. For music I "think" I would only run the Lab 12's. I have not modeled Don's tapped horn, I thought about building one but it is larger than I wanted. I know it will play significantly louder and I defer to others who have heard examples of each enclusure type (OD-ML-TL vice TH) to offer opinions on sound quality differences. |
| Chosing the taper in transmission lines, mass loaded or not | Squeak | Full Range | 0 | 12th March 2011 11:02 AM |
| Slot loaded cube box for Lab-12 driver | ashok | Subwoofers | 0 | 22nd March 2010 03:13 PM |
| Alpha Transmission line - can the driver be offset? | adamt | Multi-Way | 3 | 26th June 2006 11:36 AM |
| Mass Loaded TL - Getting started? | Dave Jones | Multi-Way | 4 | 12th April 2004 11:18 AM |
