Lab 12 Based Offset Driver - Mass Loaded - Transmission Line (OD-ML-TL) Design by Bj - Page 21 - diyAudio
Old 16th May 2013, 02:29 PM   #201
chris661's Avatar
That bright paint in the vent is a rather nice touch. I might have to borrow that for finishing my current project.
Looks good, bet it sounds as good too.
Chris
Old 16th May 2013, 02:35 PM   #202
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Chris
Thanks I borrowed that idea from Volvotreter, he does his horns like that. I was thinking of doing some lines around the edges too, give it a tron-ish look.
Old 16th May 2013, 02:48 PM   #203
chris661's Avatar
Oh no...
I just simulated my JBL GTO1214s in this enclosure. Pretty much flat to 20Hz, and good for >100Hz.
Might've found a nice Summer project. Currently its between this design and a couple more drivers in sealed cabinets, with lots of power and some eq.
What sort of weight are those things?
I'm a student, so if I do decide to build something this big, I'll have to move them each year.
You mentioned an EP 2000 amplifier (way back on page 10). Would I be right in thinking that's a Behringer Europower?
I've been thinking of getting a 2nd hand one of those for a while, as I'm finding even my most powerful amp (550w) a bit short.
Old 16th May 2013, 03:04 PM   #204
DrDyna's Avatar
Oh no...
Yeah, I currently have an EP2000, but I think these drivers can take a little more, I've never, ever heard them bottom even with 1812 cannon blasts that pop the clip indicators.
I'll weigh one in a sec.
Edit: They're about 120 lbs each.
Old 16th May 2013, 03:04 PM   #205
BP1Fanatic's Avatar
The bright paint on the port does look nice!
Old 16th May 2013, 03:25 PM   #206
DrDyna's Avatar
Last one, here they are in their spots, pics are a bit grainy, it's dark in this room.
Old 16th May 2013, 04:02 PM   #207
NWCgrad is offline NWCgrad  United States
Nice! The bright color puts them over the top.
I'm still working on the cutsheet for tb46's fold. My wife preferred it to BP1's fold as it will take up less floor space. Would have the cutsheet finished but I can't seem to focus lately.
I did model the Epic 12's in the new design, looks really good. I may end up buying a pair after I buy a new amp and MIC2200 (the HPF and two bands of parametric equalization). Right now I am leaning towards a QSC PL340 or Crest CA9 (the Mael-X can take 1400 W/4 ohms in the TTWQT design).
Old 16th May 2013, 06:16 PM   #208
DrDyna's Avatar
Yeah, I love the color, I think I might do some accent pieces on my mains the same way, but I have to be careful, the mains are close to the screen and I think brash colors might be distracting.
As far as EQ / HPF goes, with the Epic 12, depending on how much power you throw at them, I'm really hesitating to even hook the MiniDSP up and re-engage my HPF, I'm into the clip indicators with the EP2000 @ 4 ohms and I've never had any bottoming or nasty sounds (except for clipping if I let it clip hard). I'm not sure if it has anything to do with shorting rings or just the way the driver is designed.
I'm not sure about the Eminence driver, as I've never owned or tried one.
One thing I wanted to run past everyone here, but I've really been trying to find a position up front for the subs, but of all the designs I've had, I always end up with them at the back of the room. They seem way more even back there, but it's easy to tell where they are and I've been trying to get away from that sensation...which seems a lot like in a car, you can always tell the sub is in the trunk :P
For fun today, I tried turning the subs and the listening position 90 degrees, so that the listening position was along a long wall and the speakers were along the other long wall. The bass seems much, much better like this.
I'm wondering, is it because of the cement walls?
I've been wrestling with this issue in this room for a while, I wonder if anyone has an opinion on it.
Old 16th May 2013, 08:10 PM   #209
Zero D is offline Zero D  United Kingdom
@ DrDyna
Have you got any electronic delay in your system to time correct Everything together ?
Old 16th May 2013, 08:17 PM   #210
DrDyna's Avatar
Originally Posted by Zero D View Post
@ DrDyna
Yeah, the receiver has distance settings.
Chosing the taper in transmission lines, mass loaded or not Squeak Full Range 0 12th March 2011 11:02 AM
Slot loaded cube box for Lab-12 driver ashok Subwoofers 0 22nd March 2010 03:13 PM
Alpha Transmission line - can the driver be offset? adamt Multi-Way 3 26th June 2006 11:36 AM
Mass Loaded TL - Getting started? Dave Jones Multi-Way 4 12th April 2004 11:18 AM
Copyright 1999-2017 diyAudio
