Lab 12 Based Offset Driver - Mass Loaded - Transmission Line (OD-ML-TL) Design by Bj - Page 17 - diyAudio
Old 12th May 2013, 12:23 PM   #161
Zero D is offline Zero D  United Kingdom
Originally Posted DrDyna
when the girl feels like dancing
Got any pics
Old 12th May 2013, 12:49 PM   #162
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by Zero D View Post
Got any pics
Ha! This aint tumblr!
Old 12th May 2013, 12:52 PM   #163
@ DrDyna
Old 12th May 2013, 09:21 PM   #164
BP1Fanatic's Avatar
Lol!
Old 13th May 2013, 06:31 AM   #165
NWCgrad is offline NWCgrad  United States
Funny stuff their Dr Dyna!
I have been trying to translate tb46's hornresp data into an enclosure but so far am failing miserably.
Can anyone assist? Thanks, Steve
Old 13th May 2013, 12:25 PM   #166
DrDyna's Avatar
Oh, the TQWT? If it was me, I'd either build it in one tall peice, so it essentially looked exactly like the schematic looks in hornresp, or fold it over once backwards, then loop the mouth back around so it ends under the driver.
Edit: A crude sketch.
Edit2: Driver position should be higher, but, I think that's the general idea.
Old 13th May 2013, 12:41 PM   #167
BP1Fanatic's Avatar
The speaker should be mounted 85cm or a third way up the line path.
Old 13th May 2013, 12:47 PM   #168
Thanks, I had thought that's how it would look but was having doubts.
Modeled in Hornresrep and compared to the OD-ML-TL design and it is almost exact on all parameters (SPL, cone excursion, group delay, etc). Also compared to a sealed design (88.7 L, Qtc = 0.605) and at maximal cone excursion the sealed was down in SPL until 10.5 Hz, at 15 Hz the sealed was down by 6.5 dB and from 20-40 Hz was down an average of 9.@ dB (max - 11.7 dB@20 Hz; min - 6.3 dB@40 Hz). From 40 Hz to 120 Hz the sealed was down by an averagebof 3.5 dB.
Looks like tb46's little TL may be a cool option for my HT.
Old 13th May 2013, 02:25 PM   #169
GM is offline GM  United States
GM's Avatar
For [sub] bass duty [<120 Hz], just folding the long ones in half and either spacing it up for bottom firing or cutting out the terminus [mouth/'vent'] in one or more sides is fine. Also, IME there's more performance advantage to mounting the driver at the extreme closed end ['top'] to maximize boundary gain/negate floor bounce regardless of what a typical sim indicates.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th May 2013, 06:16 PM   #170
Here are my initial efforts for developing an enclosure for the model provided by tb46 (see attachment). I think the unfolded is pretty accurate, but somehow my calculated volumes did not perfectly match the Hornresp data from which the parameters were taken. Error is probably because I converted to Imperial measurements instead of working in metric.
Chosing the taper in transmission lines, mass loaded or not Squeak Full Range 0 12th March 2011 11:02 AM
Slot loaded cube box for Lab-12 driver ashok Subwoofers 0 22nd March 2010 03:13 PM
Alpha Transmission line - can the driver be offset? adamt Multi-Way 3 26th June 2006 11:36 AM
Mass Loaded TL - Getting started? Dave Jones Multi-Way 4 12th April 2004 11:18 AM
Copyright 1999-2017 diyAudio
