Lab 12 Based Offset Driver - Mass Loaded - Transmission Line (OD-ML-TL) Design by Bj
Old 10th May 2013, 06:04 PM   #151
GM is offline GM  United States
GM's Avatar
NWCgrad's OD_MLTL? Your link justs goes to the top of the page............ http://www.diyaudio.com/forums/attac...al_f3-21hz.jpg
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th May 2013, 12:08 PM   #152
DrDyna is offline DrDyna  United States
DrDyna's Avatar
GM
Sorry, it was meant to go to the post where I uploaded a picture of the one I built, it was a quick-ish assembly with extra glue and uglyness that I really did just to see how the OD-ML-TL would sound.
I've spent the last couple of days off and on putting together a pair of them with a lot more care. I have one finished and the second one just needs to have the driver opening routed and the last side glued on.
Here's the one that's done. (No finish work yet.) The other one is coming later today!
Old 11th May 2013, 05:29 PM   #153
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
I do like how the port flares out!
Old 11th May 2013, 05:35 PM   #154
NWCgrad is offline NWCgrad  United States
It does look ready for business, can't wait to hear impressions of two of them. I am leaning towards using mine in a 2 channel music only system and going with a few 18" subs for HT. But everything is subject to change. Still have a few more months before I can start cutting plywood.
Old 11th May 2013, 05:39 PM   #155
BP1Fanatic's Avatar
A TTQWT will give you a wide frequency response for both HT and music!
Old 11th May 2013, 06:04 PM   #156
I have a TTQWT design from bjorno and tb46 for my 18" maelstrom x driver. It is tuned down to 13 Hz before the freq resp plummets and cone excursion goes crazy (10 Hz HPF required).
However, the enclosure is rather large. I am beginning to think 4 sealed subs (~5 cu ft each) would provide a smoother in room response and with a little EQ could get decent output to single digits. There are some blu ray's with significant impact below 10 Hz, but I'm not sure its worth the pursuit.
I'm torn, as I have never had a bass system that could go lower than 25 Hz with any authority. Perhaps I should find another 18" driver that models well in the bjorno/tb46 TTQWT design and couple the pair with the LAB 12's. The TTWQT design's projected response gets wonky above 60 Hz. I could use the TTQWT for the ULF and the LAB's for 30 to 120 Hz (120.Hz is the upper limit for the .1 channel).
Advise always sought and carefully considered. I am closely watching DrDyna's experience with this build. I assume they would play nice with the TQWT's. I have both a Behringer and MiniDSP for knocking down the peaks, hopefully the mutli subs will minimize the nulls (should let the literature). I am learning a lot in this thread, I hope it keeps going.
Old 12th May 2013, 06:46 AM   #157
GM's Avatar
Originally Posted by DrDyna View Post
That TQWT Oliver posted, which I believe to be along the lines of what you were talking about.........
Correct.
GM
Old 12th May 2013, 07:00 AM   #158
Correct.
GM
I played with tb46's model on hornresp and it looked pretty good to my untrained eye. Everytime I learn something in hornresrep I forget it next time I use the program. It isn't vet intuitive to me.
Would be cool to "see" what his TTWQT looks like, I think it would be a great match to the Mal-X design he visualized for me. With bjorno and tb46 this adventure would have been stillborn.
Old 12th May 2013, 07:53 AM   #159
GM's Avatar
Actually, it's very good.
GM
Old 12th May 2013, 12:32 PM   #160
DrDyna's Avatar
I finished the second one yesterday and spent a little time listening to the pair of them. I'm going to have to have the placement dance, I think I'm going to end up with a lower LPF and subs toward the back of the room again, they sound a little anemic when they're up front like that. Plenty of wall-breathing down really low, but hardly any visceral "kick".
My girlfriend actually commented that she was "spoiled" on the tapped horns and wasn't very impressed..I'm going to blame 75% of it on placement.
Once I find a spot where I can get a little hair-raising out of em, I'll try some real full-power testing. To me, they have a lot of potential to be very musical and "vanishing act" type subs, but I might have to augment them with another giant tapped horn just to have something that'll suck the breath out of you for HT and for when the girl feels like dancing :P
Lab 12 Based Offset Driver - Mass Loaded - Transmission Line (OD-ML-TL) Design by BjHide this!Advertise here!
Chosing the taper in transmission lines, mass loaded or not Squeak Full Range 0 12th March 2011 12:02 PM
Slot loaded cube box for Lab-12 driver ashok Subwoofers 0 22nd March 2010 04:13 PM
Alpha Transmission line - can the driver be offset? adamt Multi-Way 3 26th June 2006 12:36 PM
Mass Loaded TL - Getting started? Dave Jones Multi-Way 4 12th April 2004 12:18 PM
Copyright ©1999-2017 diyAudio
