Tapped horn for Tang band W69-1042M
Old 15th July 2012, 03:18 AM   #1
speakrsrfun is offline speakrsrfun  Canada
speakrsrfun's Avatar
Default Tapped horn for Tang band W69-1042M
I built a tapped horn using this driver a few years back but have misplaced the hornresp file due to upgrades on my computer. I have modeled this again as I remember the line being 8-9' but I can't get a good sim with this driver without running out of xmax at low power. I seem to also remember my tuning being about 30hz and was clean until 100hz, output was fair in the110-115dB if I recall correctly. Now my issue is I like I said earlier is I can't get this driver to model well in a tapped horn and I can't for the life of me figure out why.
If I could get a little help on a modeling without issues I would be greatful, it's driving me mad. Thanks in advance.
What was that?... I can't hear you I have a line array filling my ears.
Old 15th July 2012, 04:03 AM   #2
GM is offline GM  United States
GM's Avatar
Dunno, just running some numbers, it takes a 1 pi loading to get 110-115 dB.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th July 2012, 04:10 AM   #3
GM's Avatar
Hmm, then again, it can be 'grown' from ~109 to 188 L and will sim these numbers in 2 pi.
GM
Old 15th July 2012, 11:55 AM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI:
b
Old 15th July 2012, 03:20 PM   #5
GM's Avatar
Hmm, your specs are considerably different than what I found on the net, so curious where you found them plus need to use the same peak SPL plots for comparison purposes.
GM
Old 15th July 2012, 03:46 PM   #6
GM
Hi Greg,
I found the T/S data here:
FS:Tang Band W69-1042M 6"x9" Subwoofer - Free Shipping
b
Old 15th July 2012, 06:33 PM   #7
bender460 is offline bender460  United States
I've been curious about a dual driver T-TQWT using this driver. It may proved the extra output wanted given the limited Xmax of the driver.
I remember a good build using two 8"x12" drivers. I wish they were still available.
Old 15th July 2012, 07:10 PM   #8
FYI,
In case you can get hold of those drivers:
b
File Type: jpg TB-W69-1042m_1-Driver-T-TQWT_2xOD-T-QWP.JPG (477.1 KB, 314 views)
Old 15th July 2012, 10:49 PM   #9
Originally Posted by bjorno View Post
FYI,
b
I just noticed the part numbers...
I was looking at...
Tang Band W69-1042J 6"x9" Subwoofer 264-837
Old 16th July 2012, 08:00 AM   #10
I was looking at...
Changing the suffix from m to j is the only thing that would differ besides that the drivers would be in parallel and max power lowers from ~80W to ~70W.
b
Tapped horn for Tang band W69-1042MHide this!Advertise here!
Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendation permo Subwoofers 212 4th December 2015 02:15 PM
Fostex FE127E + Tang Band W69-1042M edinm Multi-Way 3 11th March 2010 09:55 AM
FS: 2 Tang Band W69-1042J 6"x9" Subwoofer: $75 + shipping zobsky Swap Meet 0 29th March 2009 05:16 PM
fs tang band w4-1320 and w69-1042 - uk or europe needmorstuff Swap Meet 2 14th January 2009 08:21 AM
FS:Tang Band W69-1042M 6"x9" Subwoofer - Free Shipping YFW Swap Meet 3 15th August 2008 12:51 AM
