which subwoofer for 250W@4ohms class D amp ? - Page 2 - diyAudio
Old 15th July 2012, 12:39 PM   #11
Tank you everybody !!!!!!!
I entered the speakers you've talked about in my previous table (the -supposed- best one on the top).
The values have been calculated only with T&S parameters for Bass Reflex (Bessel) : I don't know if they are far from reality or not........
I don't know if 4th order bandpass would be a good solution too...
And what do you think about Monacor SPH390TC in bessel BR ?
Old 15th July 2012, 01:15 PM   #12
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI: To make a true 'Bessel' ported box, you need drivers with a Qts of close to 0.33.
b
Old 15th July 2012, 03:39 PM   #13
For to be used as a sub: I would consider to build a T-TQWT with sloping FR instead of any BR.
b
Old 15th July 2012, 06:57 PM   #14
Inductor's Avatar
FroggySeven, can't you use the Eminence Legend BP102, in all similar to the Monacor SPH390TC, only 92.0 dB/2.83V/m (E) vs. 95.0 dB/2.83V/m (M), smaller basket 10" vs 15", and a smaller enclosure?
Certainly that with a big enclosure my choice would be different as bjorno shows 213 L for the Monacor.
Also check the new BEYMA 10BR60 v2011 with 90.0 dB/2.83V/m.
Also consider that, when the footprint/size of the enclosure (VB) is small plus the price of the drivers you can double (2x) the drivers and add 6dB's to the total output/sensitivity.
Old 15th July 2012, 07:38 PM   #15
Inductor's Avatar
It's for home, so no problem up to 150L (but the smaller, the better...and why not bigger if it is worth)
Also give some consideration for the type of speakers you're building, here sealed type notes from tvrgeek-diyAudio
Many sub questions
Old 16th July 2012, 04:09 PM   #16
I must admit I don't understand what "tapped horn" or "PPSL" is.
bjorno : I think I have understood on the picture what is " T-TQWT with sloping FR ".
I think this would be really funny in a horizontal position with a glass table on !!!
But I am not able at all to make the plans...
Which speaker do you used ?
Old 16th July 2012, 04:24 PM   #17
Hi, Your idea of a horizontal deign would work well with two folds..I used the first driver in you performance/prize list: The Monacor SPH390TC and this name is also stated in the HR Input screen.
b
Old 17th July 2012, 08:29 PM   #18
I bought two SPH390TC today on the net !!! I hope they'll come soon )
I think I will be able to adapt your plan to a more circular outline.
I'll tell you when the speaker will arrive
Old 18th July 2012, 01:30 AM   #19
Inductor's Avatar
FroggySeven, congratulations for your new future project build.
Hope you like the drivers. A little big for me, but without any more components in your system to match with it's going to be funny to watch how it will end up. A system like that it's going to require lot's of space.
Old 18th July 2012, 06:38 AM   #20
Of course I hesitated about the volume with Eminence Legend BP102, BEYMA 10BR60, and Atohm D300P0...
And it's not only about the WAF : wood is expensive too !!!
But if the SPL in enough, I'll perhaps use only one speaker, so...
(and I have two other projects in mind to use the second one if necessary).
subwoofer powered by class t-amp? HifiBoyDenmark Subwoofers 10 10th May 2012 05:02 PM
best class d amp for subwoofer sasek Class D 1 19th May 2011 06:19 PM
Looking 500W 4ohms amplifier for Polk Subwoofer samsagaz Subwoofers 4 24th June 2009 09:47 AM
NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale magnum_1 Swap Meet 16 13th June 2009 04:59 PM
PE 250W Subwoofer Plate Amp pjanda1 Swap Meet 2 27th March 2007 04:15 PM
Copyright 1999-2017 diyAudio
