can someone please help me design an enclosure for my subwoofer
Old 9th July 2012, 04:28 PM   #1
vishnupg is offline vishnupg  India
Default can someone please help me design an enclosure for my subwoofer
i am designing a 5.1 hometheater system.i have designed my amplifiers and i am using lm3886 parellel with dc servo for my sub.
My knowledge in designing enclosure for sub is very less....so please help me attain the best performance
Old 9th July 2012, 04:32 PM   #2
i think vented design will be good
i am using the following woofer Iwai Electronics Pvt. Ltd.
Old 9th July 2012, 08:06 PM   #3
tb46 is offline tb46  United States
Hi vishnupg,
You are providing no help as to your application, enclosure size, room size, placement, etc.
Anyway, to get things started: Hornresp is a free design software that you might find helpfull:
Hornresp
After downloading and installing, please, read through the help file, it is quite informative.
The speaker you are referencing does not look like much of a subwoofer, and I would recommend you measure the T/S parameters yourself (in addition to what you have in the specification sheet) before you spend a lot of time on designing, or cutting wood:
Measuring Loudspeaker Driver Parameters
Oliver
Old 9th July 2012, 09:21 PM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi vishnupg,
Submitting a suggestion that I think would suit a LM3886 amp:
b
Old 11th July 2012, 03:10 PM   #5
thankyou very much guys......i have started with enclosure
Old 12th July 2012, 04:53 AM   #6
GM is offline GM  United States
GM's Avatar
FWIW, some measured specs:
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th July 2012, 02:37 PM   #7
GM
Hi GM,
Good news!
I plugged your numbers into my previously submitted simulation and found the measured T/S to be slightly improving the suggestion despite the new driver Sd is larger than the advertised..
The driver would still fit the enclosure with CSA= 224cm^2 as long as the internal width is close to 21 cm.
b
Old 12th July 2012, 03:12 PM   #8
GM's Avatar
GM
Old 15th July 2012, 02:45 PM   #9
The driver is good one for the price right??
Old 15th July 2012, 03:45 PM   #10
Who knows the price but you? You're the one who suggested a driver from India. Mail the driver manufactures and post to this thread.
b
can someone please help me design an enclosure for my subwooferHide this!Advertise here!
Subwoofer enclosure Non-parallel enclosure to reduce standing waves qguy Subwoofers 4 4th July 2011 10:35 PM
Subwoofer enclosure design Cyberzim Subwoofers 23 22nd May 2009 08:17 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 11:31 AM
subwoofer enclosure design questions halbritt Subwoofers 3 23rd March 2004 03:18 PM
Best way to design a subwoofer enclosure soundNERD Subwoofers 11 30th October 2003 07:16 AM
