Hello
I finished building my little sub project. I wanted to build a relatively compact design with volume of approximately 30..40 liters. I measured the T/S parameters of the woofer, and closed enclosure type was chosen as the driver has a medium Q value (Qts=0,48) and quite low resonance frequency (Fs=30,4 Hz). Also it might be tricky to fit a long and wide enough bass-reflex tube for ~20 Hz tuning inside such a small enclosure. The total Q value for the driver in a 38 liter closed enclosure would end up in the "optimal" range of ~0,7. The backside has a modified 120W plate amp. Originally it had an unadjustable 2nd order +6 dB@40 Hz peaking highpass filter. By changing some components on the PCB, the filter was modified to a flat frequency response. With these changes, there is some output down to ~25 Hz when the crossover frequency is adjusted low enough to integrate with the main speakers. When I tested it with some 16..17 Hz sine signals, the windows of my house started to vibrate and it made me flinch! ![]() Scan-Speak's 10" woofer 26W/4558T00 would also fit this enclosure well. Using this driver might improve the bass extension to some degree. So far I am very satisfied with the performance of my first DIY subwoofer.
#2 |
Nice work. Which driver is that? It looks like a car audio driver...
www.diysubwoofers.org |
#3 |
Thanks,
I don't know the brand/model. But according to the measurements, its electro-mechanic parameters are: Fs: 30,4 Hz Qes: 0,54 Qms: 3,4 Qts: 0,465 Vas: 48,27 L Sd: 335 cm² Re: 4,1 Ω |
| kinda ot... 10" x 10" x 10" aluminum block/bar, does such thing exist? | Mickey | Pass Labs | 9 | 15th November 2011 08:22 PM |
| Peerless XXSL 10" Small enclosure | KI | Subwoofers | 20 | 4th October 2009 01:54 AM |
| Small XLS 10" sub, one or two PR? | Supernaut77 | Subwoofers | 2 | 28th September 2006 02:56 PM |
| WTB: a small 8" or 10" subwoofer | justpoor | Swap Meet | 0 | 26th February 2006 09:05 AM |
| Suggestions for small (8"/10") subwoofer driver? | netgeek | Subwoofers | 17 | 22nd December 2003 06:01 PM |
