Commercial enclosure for exodus anarchy 6.5 inch
Old 27th June 2012, 01:26 AM   #1
john dozier is offline john dozier  United States
john dozier's Avatar
Default Commercial enclosure for exodus anarchy 6.5 inch
I have been looking at the 25hz tapped horn flat pack for this driver. Are there any other kits that would be suitable? I am not concerned with 25hz response, 35-40 would be fine I have NO woodworking skills or equipment, thus I need a commercially available enclosure. Flat pack is ok. Any suggestions? Thanks
Evil looms. Cowboy up. Kill it. Get Paid.
Old 27th June 2012, 04:24 AM   #2
m R g S r is offline m R g S r  United States
Volvotretters 38hz tang band double folded tapped horns. I have a pair that I enjoy. Check those out on his webpage
Try Simming the exodus in that cabinet, might work well!
Old 27th June 2012, 10:36 AM   #3
Unfortunately, I need an assembled or flat pack enclosure. A small sealed or tube loaded would work. Thanks
Old 27th June 2012, 11:51 AM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI,
DIY a TH by converting small # of dimensional changes from Volvotreters design using the TangBand_W6-1139SC to your own using the Exodus Audio Anarchy driver. Try use the submitted information:
b
File Type: jpg Exodus-6.5inch-Anarchy-instead-of-Tangband W6-1139G.jpg (423.0 KB, 248 views)
Old 27th June 2012, 12:41 PM   #5
Josephjcole is offline Josephjcole  United States
Josephjcole's Avatar
What is it about the TH flat pack that you don't like? I know you said that you don't need 25Hz, but that doesn't seem like too much of a problem. They seem well designed and the guy is selling them at no profit, which is somewhat incredible really. I certainly wouldn't hesitate to buy one if it fit my needs.
Joe
Old 27th June 2012, 01:11 PM   #6
Joe
I would hesitate if the use of this TH is primarily for music as the so called 'TH flat-pack' suits IMO only HT when used a long with a HT amp that can take care of and adjust the group-delay that otherwise would screw up the timing fidelity for any good stereo speaker system.
Volvotreters design is in that respect not flawed at all.
b
Commercial enclosure for exodus anarchy 6.5 inchHide this!Advertise here!
Best 10 inch sub drivers for sealed enclosure brox Subwoofers 21 6th July 2014 08:05 AM
starting new MTM 2 x Exodus Anarchy + Scan Discovery Tweeter _henry_ Multi-Way 11 27th November 2011 08:13 AM
Exodus 21 inch Moondog55 Subwoofers 5 16th October 2011 02:03 PM
Exodus Anarchy offset horn for car JustinG Car Audio 6 21st May 2010 04:19 PM
what type of enclosure to use for 6.5 inch Bolton somakmaitra Multi-Way 7 10th February 2006 06:12 AM
Copyright ©1999-2017 diyAudio
