Is time delay necessary with tapped horns
Old 24th June 2012, 06:46 PM   #1
john dozier is offline john dozier  United States
john dozier's Avatar
Default Is time delay necessary with tapped horns
I am planning on adding two 25hz tapped horns to augment my Paradigm Sig1s. Do I really need to delay the Paradigms? Every time delay unit I have heard does nasty things to the SQ. Can I get by without the delay and still have good integration assuming a 24db low pass. Thanks
Evil looms. Cowboy up. Kill it. Get Paid.
Old 24th June 2012, 08:36 PM   #2
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
Every instance of discussion that I have read about TH's ,when the discussions get technical there is mention of delay. I've seen numbers from a few millisecs up to 16 ms. I'm sure every design has its own inherent amount.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 25th June 2012, 05:19 PM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
IMO, If the Pre-Pulse is separated from the Main-Pulse more than ~10 mS:
The Main speakers needs to be 'time' aligned with the TH:s using signal delays.
10 mS is the typical ear integration (fusing) time when listening to music.
Within this time the localization cues and sound onset(attack) characteristics are established but not the ear/brain pitch determination for signals below ~100Hz as they need more than ~3 periods to be tonally heard.
Most TH:s that are digging lower than ~30 Hz have a large time separation between the front and rear acoustical signals.
In that respect I find T-TQWT's are superior (SQ-wise too) compared to TH:s as they normally are designed without needing signal delay's for the Main speakers or to be FR tamed using EQ's.
I don't think signal delay units are to be blamed if bad SQ appears but instead the operator of the equipment when doing a lousy system integration of the speakers.
b
Old 3rd July 2012, 08:35 PM   #4
mattlong8 is offline mattlong8  United States
mattlong8's Avatar
If I recall correctly aligning TH-118s to SH-60s separated by about 6' had a 7-11ms delay depending on the room and the angle of the SH-60.
-Matt Long
San Francisco, CA
Is time delay necessary with tapped hornsHide this!Advertise here!
delay line settings to time-align DTS-10 tapped horn to mids & high drivers cyclecamper Subwoofers 4 20th April 2011 06:52 AM
last segment of tapped horns bubblersound Subwoofers 0 2nd April 2011 12:14 PM
NEED to hear some Tapped Horns Top Shelf Subwoofers 60 15th August 2010 07:10 PM
Dampening in Tapped Horns?? atilsley Subwoofers 25 20th June 2009 08:24 AM
how to model tapped horns? weikertball Subwoofers 2 11th January 2009 09:43 PM
Copyright ©1999-2017 diyAudio
