Woofer Driver Needs a Home Built for it - Page 2 - diyAudio
Old 28th July 2012, 10:45 PM   #11
...(quick read). I've not used anything like that unit before. Am I to understand that it could perform the Linkwitz transform as well as the crossover duties? And would it also be able to output a balanced signal to drive bridged amp setup to drive the woofer?
Old 28th July 2012, 11:15 PM   #12
I suppose more clearly, I mean can the mini dsp unit act as a crossover, and then perform a linkwitz transform on the low end output, and invert the phase of one of those low end outputs?
Old 29th July 2012, 01:07 PM   #13
Yes, plus time correction and parametric eq.
Old 30th July 2012, 10:21 AM   #14
Default That sounds pretty good for prototyping
for the price that seems like a pretty flexible tool to nail down the parameters... Hmm, You've temped me, but I'll have to see if the budget can be made to stretch to that. Thanks for the suggestion!
Old 8th November 2012, 02:10 PM   #15
Default Progress!
So - I went and built me a 250W Class D amp (with something a little gruntier to come) and scored a minidsp-inabox second hand for a fair price...
And now I'm having a little bit of a play with the whole lashup! I just wandered outside to make sure the house wasn't sounding like a nightclub at 11pm on a thursday.
I've manually entered an eq that kind of replicates a linkwitz transform roughly - seems I need to learn all the speaker language now, so I can program in a proper linkwitz transform into the minidsp for the components i have here. Qts, Qs, Fo, Rsvp, etc etc
In terms of driver specs/data all I really have to go on is the below graph from the datasheet mentioned in one of the previous posts (relevant bits below), and obviously thats for a completely different setup. Any suggestions for the relevant parameters anyone?
Well, I'll keep experimenting!
Old 8th November 2012, 02:18 PM   #16
Default down or out?
Oh, and I initially set thus up to be downward firing (I read somewhere that it would likely make no difference) but I'm somewhat dubious - Any comments anyone?
Old 8th November 2012, 05:03 PM   #17
chris661's Avatar
It has wheels that will space it far enough off the floor, so try it!
You might find it gets used as a coffee table, until you crank it up.
HTPC for my home built projector Projector Project PC Based 0 6th January 2011 04:52 AM
Home built subwoofer driver flyingtele Subwoofers 13 3rd August 2009 04:28 PM
Can't get home built amp working ackeron42 Solid State 3 13th November 2006 06:35 PM
Built-in home entertainment SuppersReady Everything Else 23 12th November 2003 09:17 AM
Copyright 1999-2017 diyAudio
