Concept, Beolab 11 style isobaric sub using Ikea Blanda metal bowls. - Page 4 - diyAudio
Old 30th June 2012, 09:57 AM   #31
Quick sketch, but to scale (magnet size was a guess)
4x5" drivers, or 2x6"
I don't personally like the larger gap
Old 30th June 2012, 11:11 AM   #32
chris661's Avatar
You have the 5"ers mounted isobarically - that isn't what I suggested, and won't give the same performance as the simulations I posted either.
Old 30th June 2012, 11:18 AM   #33
ok, two outward facing drivers in each half sphere?
Without hogging its on dsp (2in 4out) is there a way to wire this up so the drivers can share the signal?
Old 30th June 2012, 12:00 PM   #34
chris661's Avatar
Yep.
A series-parallel arrangement of all 4 would give a 4 ohm (nominal) load for a single amplifier channel.
You could wire each pair in series to give an 8ohm load for 2 channels of amplification.
For the 6"ers, you'd have either a single 8ohm or 2ohm, or two lots of 4 ohm if you have a stereo amplifier.
Chris
Old 30th June 2012, 02:29 PM   #35
djk is offline djk
djk's Avatar
You will find it hard, if not impossible, to port this small of an enclosure to a low frequency.
If I was fixated on this project I would use a pair of sealed long excursion 8s or 10s, and either a Linkwitz Transform or an ELF crossover (Bag End).
Candidates for the Darwin Award should not read this author.
Old 2nd July 2012, 07:49 PM   #36
is this due to the small enclosure or the small port size?
Could the port be routed through the other bowl, imagine a snake twisting through both.
I think lots can be done with the MiniDSP, due you know of a 8 or 10" sub that can work in a sealed 11l enclosure?
Old 2nd July 2012, 08:01 PM   #37
Did it Himself
richie00boy's Avatar
The problem with small boxes and ported subs is that to get decent clean output you need to have a good amount of port area (meaning longer port needed), and the sub use dictates low tuning (longer port needed again). So fitting the port into the box becomes physically impossible.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 2nd July 2012, 08:15 PM   #38
djk is offline djk
djk's Avatar
"due you know of a 8 or 10" sub that can work in a sealed 11l enclosure? "
Any driver with a good x-max will do. The Qtc will be quite high, that's what the Linkwitz Transform is for.
Some of the Velodyne and Bag End designs have sealed system resonances around 80hz or so.
Old 2nd July 2012, 08:22 PM   #39
tvrgeek is offline tvrgeek  United States
Nice drawings P10. Should clear up come comments in several threads.
My take:
isobarik is an expensive way to not buy a more expensive driver.
The idea of big metal bowls gives me shivers, but as subs, well it's the volume that matters. The ones in the photo look WAY too small to be subs. Please do your T/S calculations.
Old 2nd July 2012, 08:48 PM   #40
We are talking about 11" bowls, 5" drivers, and the word "sub" in the same thread?
Here is an idea. Pull up a copy of WinISD. Pick any speaker and do a sim of a sealed box. Make the box 11L. Then go into the editor and keep changing Fs and Qts until you get numbers that look like a sub. Look around for drivers like that. When you find one, let us all know.
For what I consider a real sub, the Peerless 12" in 60L is one of the smallest and one of the cleanest. Very good efforts have been done with several 8's, but the total box size goes up a lot. 200L is not an unreasonable size for a sub.
Subs don't have to be in the same room. Only their output. They can be in attics, adjacent rooms, under the floor, outside. Creativity here is the rule.
B&O Beolab 11 - how does it work? natumbri Subwoofers 12 20th August 2013 12:37 PM
Beolab 5 clones!!!!! legendaryfrog Multi-Way 72 16th April 2013 12:31 AM
WTB: 4x Ikea BLANDA bowls, 8" or 12" Spasticteapot Swap Meet 7 11th March 2010 05:46 AM
Ikea Bowls question joe58 Full Range 2 27th February 2010 05:11 PM
Copyright 1999-2017 diyAudio
