Concept, Beolab 11 style isobaric sub using Ikea Blanda metal bowls.
Old 26th June 2012, 08:35 AM   #11
djk is offline djk
R.I.P
djk's Avatar
"(cancelling 2nd order without doing anything about 3rd order creates a non-monotonic series of harmonics). "
Then you must not like servo subs either.
I've listened to both, and prefer not to have the 'mud'.
Candidates for the Darwin Award should not read this author.
Old 26th June 2012, 08:44 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Never heard a servo sub.
If you use good drivers, push-pull gains you little (ref Llambda Nick), and reduces the effectiveness of force cancelation. So i use good woofers & choose to maximize force cancellation.
The only mud is out in the yard after it rains.
I do have a pair of pushpush-pushpull box in the works, my thinking being that to do push-push without sacrificing force cancellation one needs to use 4 woofers/box.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th June 2012, 12:18 PM   #13
Studio Au is offline Studio Au  United Kingdom
Thanks for the images.
So is the consensus push-push will be best?
Have been eying the Peerless XLS10 on ebay 69, half the cost of the Scan-Speak. Will they work, will they be good? Any better recommendations?
Peerless XLS10 Subwoofer P830452 Loudspeaker - Speaker. | eBay
Here are the specs:
Specifications
Nominal Impedance (Ohms)
Zd
4
Min Impedance
Zmin
5.2
DC Resistance (Ohms)
Re
3.6
Voice Coil Inductance (mH)
Le
0.99
Resonant Frequency (Hz)
Fs
22
Mechanical Q Factor
Qms
3.86
Electrical Q Factor
Qes
0.24
Total Q
Qts
0.23
Moving Mass (g)
Mms
136.6
Suspension Compliance (mm/N)
Cms
390um/M
Effective Cone Diameter (cm)
D
21.1
Effective Piston are (cm2)
Sd
349.7
Equivalent Volume (Ltrs)
Vas
66.90
Force Factor
Bl
16.75
Reference Voltage Sensitivity
dB
86.6
Weight of Magnet (kg)
2.42
Old 26th June 2012, 12:40 PM   #14
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
A 36cm Hemisphere is approx 12 Litres.
Insert a 12m baffle with cutout and you down to 11.5 Litres! Subtract the driver volume from that again then calculate the bass response for a sealed cab. Methinks it might roll off quite high for a bass cab.....
Old 26th June 2012, 12:54 PM   #15
djk is offline djk
R.I.P
djk's Avatar
Looks like a pair of 6-1/2s are in order, and boost below 50hz.
Old 26th June 2012, 04:52 PM   #16
@Xoc1 any way to help this along? The two cabinets will be joined i reckon a total of 19L.
Could run x4 like Planet 10's first picture the gap containing 2 magnets sticking out?
Would always rather have less better quality drivers than more cheap ones.
@djk, any recommendations for a 6-1/2" sub woofer?
I hear lots of people talking about Tang Band, just seem really hard to find in the UK.
Tons of drivers on eBay, hard to filter out the less than ideal stuff.
Old 26th June 2012, 06:46 PM   #17
chris661 is offline chris661  United Kingdom
chris661's Avatar
These'll do the job.
W6-1139SIF - TB speakers 6 inch paper cone subwoofer - Europe Audio
I use mine (earlier Neodymium version, basically the same) in a 11L ported box each and think they're brilliant.
They'll go lower, louder, in tapped horns, but the THs I used were many times that cabinet volume.
Watching with interest
Chris
Old 28th June 2012, 08:40 AM   #18
50 Uk $45 Us. Grrr
Look good though, would they work well in a sealed 11L enclosure?
Old 28th June 2012, 12:29 PM   #19
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Studio Au View Post
50 Uk $45 Us. Grrr
You may find answers here:
b
Old 28th June 2012, 12:32 PM   #20
Really wish I knew what I was looking at?
Doesn't seem like a very smooth response in any of the graphs.
Concept, Beolab 11 style isobaric sub using Ikea Blanda metal bowls.Hide this!Advertise here!
B&O Beolab 11 - how does it work? natumbri Subwoofers 12 20th August 2013 12:37 PM
Beolab 5 clones!!!!! legendaryfrog Multi-Way 72 16th April 2013 12:31 AM
WTB: 4x Ikea BLANDA bowls, 8" or 12" Spasticteapot Swap Meet 7 11th March 2010 05:46 AM
Ikea Bowls question joe58 Full Range 2 27th February 2010 05:11 PM
