Different drivers in same sealed cabinet - diyAudio
Old 19th June 2012, 05:06 PM   #1
Default Different drivers in same sealed cabinet
What are the effects of using two drivers with differing T/S parameters in the same sealed sub-woofer enclosure?
(Qts: .40, .56; Vas: 149 l, 157 l; Fs: 16, 21)
Old 19th June 2012, 09:27 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Quick answer:
Coupled oscillators.
http://physics-animations.com/Physic...sh/bit_tmp.htm
Mechanics
Click on ?-mark at: Coupled oscillators.
Put your cursor over the picture with:Coupled spring oscillators. Beating effect.
Watch the effect.
Imagine the spring is the air-volume i a speaker-box, When both drivers are with different TS parameters fighting against the same air spring a beating effect occurs...The 'weaker' driver will suffer most.
b
Old 19th June 2012, 11:46 PM   #3
diyAudio Member RIP
Its not a coupled oscillator due to the intrinsic damping if connected in parallel.
More details are really needed to ascertain if dividing the box evenly will help.
rgds, sreten.
Old 20th June 2012, 04:38 AM   #4
Default Can use single volume also!
Hi, Nestorovic and Modaferri did some interesting things with dissimilar drivers in the same volume.
Modaferri's 1983 patent in particular looks very interesting: by adding increasing phase shift to one of the drivers, starting with very little at ultra-low and gradually increasing to 180 degrees at higher, he was able to get up to +6dB more low bass when compared to a single driver or two in parallel in equivalent volume enclosures. He also was able to significantly reduce the impedance bump in the lows.
Have a look at the patent at
PAT2PDF - Free PDF copies of patents: Download and print!
It may come up with an error message, but when you conduct the search on 4403112 the info will come up. It's 21 pages of REALLY interesting work which directly addresses how to do it. And the patent has expired so we're all free to play with it.
I've previously done some 2.5 type enclosures with identical drivers but a lower freq roll-off on one driver. It worked better than predicted in the sims, with more extended bass than it was supposed to have. Now I know why! Turns out Modaferri covered a similar example in his patent and predicted much more bass extension with his models. I'll be trying something like his examples with larger phase shift real soon, looks like a great way to build subs.
Commercial Site: www.HologramAcoustics.com
Old 20th June 2012, 06:20 AM   #5
Radugazon's Avatar
There is already a name for a less elaborated variant : Double Driver Dynamic Loading for Low Q Drivers, or dddllqd.
some details are available in the Single Driver Website, but the link supposed revealing the theory is dead for me.
Old 22nd June 2012, 11:53 AM   #6
djk is offline djk
djk's Avatar
The Wilson Audio X-1 had a 12" glass-fiber-reinforced pulp-cone upper woofer, and a 15" pulp-cone lower woofer in a single vented enclosure.
Candidates for the Darwin Award should not read this author.
Old 22nd June 2012, 01:12 PM   #7
Zero D is offline Zero D  United Kingdom
Lightbulb DDDL
@ Radugazon
RE - Double Driver Dynamic Loading for Low Q Drivers
And the dead link http://www.fortunecity.com/rivendell...d/dddllqd.html
I was able to retrieve it from the Wayback Machine http://web.archive.org/web/200502121...d/dddllqd.html
The first time I advanced the original idea any number of professional speaker designers jumped up and told me flat out: "This WILL NEVER WORK".
Only Servodrive Inc's Tom Danley and Jean-Michel Le Cleac'h encouraged me and offered some assistance, so most what is written here is attributable more to those gentlemen than to myself.
Old 22nd June 2012, 01:55 PM   #8
diyAudio Member RIP
Default DDDL
The DDDL principle certainly works but uses drivers with wildly different
parameters. In this case without knowing driver sensitivities and Xmax
its not easy to say, but I imagine they won't be fine in the same box.
All depends on what they are and what your trying to do with them.
rgds, sreten.
4x10 cabinet - ported or sealed? chris661 Instruments and Amps 4 23rd January 2012 04:58 PM
Sealed Cabinet - Can This Be Right? Karl71 Wild Burro Audio 14 14th April 2011 06:21 PM
Woofer choice in 2-way sealed cabinet tinos5601 Multi-Way 1 13th March 2007 04:55 AM
Sealed sub: cabinet size?? Klimon Subwoofers 4 10th August 2006 11:26 AM
Sealed cabinet speakers Zepper Multi-Way 3 21st May 2004 11:34 AM
Copyright 1999-2017 diyAudio
